Problems to add more services next to NUS
Hi there,
In my SDK12- SD132 NRF52 app, I'm running NUS ok, and I want to add two more services. So, I made this changes at ble_stack init:
ble_enable_params.common_enable_params.vs_uuid_count =4;
ble_enable_params.gatts_enable_params.attr_tab_size = 2000;
In services_init function, I added boths new services initializers, same as on_ble_evt, with respective handlers.
All seems to be ok, but I get a hardfault at sd_ble_gatts_characteristic_add in the last service.
If I comment anyone of the three services (at services_init) the app works fine and I can see this services with the nrf connect app.
Its a memory issue, i'm sure. I tried incrementing even more attr_tab_size, but it doesn't help.
What am I missing?
Update:
Hi, Looking with more detail, I was wrong. The hard fault don't occur at sd_ble_gatts_characteristic_add, but two lines before. Here:
ttr_char_value.init_len = p_tcs_init->p_init_vals->dev_name.len;
Its a simple value assignation. The hardfault I get is:
HardFault next to last line
Where p_stack_address is 0x200046F0.
My RAM 1 setup is: 0x20004068 - 0xD380
So its seems to be a ram problem. But I don't know what to do... Help!
  • Hi Mariano, I try to add HR in ble_app_uart and it can works. SDK12-SD132/Nrf52823 PCA10040.
        static ble_nus_t m_nus;
    static ble_hrs_t m_hrs;
    static uint16_t  m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
    static ble_uuid_t m_adv_uuids[] = {
    {BLE_UUID_NUS_SERVICE,        NUS_SERVICE_UUID_TYPE},
    {BLE_UUID_HEART_RATE_SERVICE, BLE_UUID_TYPE_BLE},
    };  /**< Universally unique service identifier. */
    #define HEART_RATE_MEAS_INTERVAL         APP_TIMER_TICKS(1000, APP_TIMER_PRESCALER)  /**< Heart rate measurement interval (ticks). */
    APP_TIMER_DEF(m_heart_rate_timer_id);
    static void heart_rate_meas_timeout_handler(void * p_context)
        uint32_t        err_code;
        uint16_t        heart_rate;
        UNUSED_PARAMETER(p_context);
        heart_rate = 58;
        err_code = ble_hrs_heart_rate_measurement_send(&m_hrs, heart_rate);
        if ((err_code != NRF_SUCCESS) &&
            (err_code != NRF_ERROR_INVALID_STATE) &&
            (err_code != BLE_ERROR_NO_TX_PACKETS) &&
            (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            APP_ERROR_HANDLER(err_code);
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
    static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
        for (uint32_t i = 0; i < length; i++)
            while (app_uart_put(p_data[i]) != NRF_SUCCESS);
        while (app_uart_put('\r') != NRF_SUCCESS);
        while (app_uart_put('\n') != NRF_SUCCESS);
    static void timers_init(void)
        uint32_t err_code;
        // Initialize timer module.
        APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
        err_code = app_timer_create(&m_heart_rate_timer_id, APP_TIMER_MODE_REPEATED, heart_rate_meas_timeout_handler);
    static void timers_start(void)
        uint32_t err_code;
        err_code = app_timer_start(m_heart_rate_timer_id, HEART_RATE_MEAS_INTERVAL, NULL);
        uint32_t       err_code;
    	  ble_hrs_init_t hrs_init;
        ble_nus_init_t nus_init;
        uint8_t        body_sensor_location;
        // Initialize Heart Rate Service.
        body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_WRIST;
        memset(&hrs_init, 0, sizeof(hrs_init));
        hrs_init.evt_handler                 = NULL;
        hrs_init.is_sensor_contact_supported = true;
        hrs_init.p_body_sensor_location      = &body_sensor_location;
        // Here the sec level for the Heart Rate Service can be changed/increased.
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_hrm_attr_md.cccd_write_perm);
        BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.write_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_bsl_attr_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_bsl_attr_md.write_perm);
        err_code = ble_hrs_init(&m_hrs, &hrs_init);
        uint32_t err_code;
        APP_ERROR_HANDLER(nrf_error);
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
    static void on_ble_evt(ble_evt_t * p_ble_evt)
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                break; // BLE_GAP_EVT_CONNECTED
                break; // BLE_GAP_EVT_DISCONNECTED
                // Pairing not supported
                break; // BLE_GAP_EVT_SEC_PARAMS_REQUEST
                break; // BLE_GATTS_EVT_SYS_ATTR_MISSING
            case BLE_GATTC_EVT_TIMEOUT:
                break; // BLE_GATTC_EVT_TIMEOUT
            case BLE_GATTS_EVT_TIMEOUT:
                break; // BLE_GATTS_EVT_TIMEOUT
            case BLE_EVT_USER_MEM_REQUEST:
                err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gattc_evt.conn_handle, NULL);
                break; // BLE_EVT_USER_MEM_REQUEST
            case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
                ble_gatts_evt_rw_authorize_request_t  req;
                ble_gatts_rw_authorize_reply_params_t auth_reply;
                req = p_ble_evt->evt.gatts_evt.params.authorize_request;
                if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
                    if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
                        if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
                        auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
                        err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
        &auth_reply);
            } break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
    #if (NRF_SD_BLE_API_VERSION == 3)
            case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST:
                err_code = sd_ble_gatts_exchange_mtu_reply(p_ble_evt->evt.gatts_evt.conn_handle,
                                                           NRF_BLE_MAX_MTU_SIZE);
                break; // BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST
                // No implementation needed.
    static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
        ble_conn_params_on_ble_evt(p_ble_evt);
        ble_nus_on_ble_evt(&m_nus, p_ble_evt);
    	  ble_hrs_on_ble_evt(&m_hrs, p_ble_evt);
        ble_advertising_on_ble_evt(p_ble_evt);
        bsp_btn_ble_on_ble_evt(p_ble_evt);
        uint32_t err_code;
        nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
        // Initialize SoftDevice.
        SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
        ble_enable_params_t ble_enable_params;
        err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                        PERIPHERAL_LINK_COUNT,
                                                        &ble_enable_params);
        //Check the ram settings against the used number of links
        CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
        // Enable BLE stack.
        ble_enable_params.gatt_enable_params.att_mtu = NRF_BLE_MAX_MTU_SIZE;
        err_code = softdevice_enable(&ble_enable_params);
        // Subscribe for BLE events.
        err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
                    err_code = ble_advertising_restart_without_whitelist();
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') || (index >= (BLE_NUS_MAX_DATA_LEN)))
                    err_code = ble_nus_string_send(&m_nus, data_array, index);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    static void uart_init(void)
        const app_uart_comm_params_t comm_params =
            RX_PIN_NUMBER,
            TX_PIN_NUMBER,
            RTS_PIN_NUMBER,
            CTS_PIN_NUMBER,
            APP_UART_FLOW_CONTROL_DISABLED,
            false,
            UART_BAUDRATE_BAUDRATE_Baud115200
        APP_UART_FIFO_INIT( &comm_params,
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advdata_t          advdata;
        ble_advdata_t          scanrsp;
        ble_adv_modes_config_t options;
        // Build advertising data struct to pass into @ref ble_advertising_init.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = false;
        advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        //advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        memset(&scanrsp, 0, sizeof(scanrsp));
        scanrsp.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        scanrsp.uuids_complete.p_uuids  = m_adv_uuids;
        memset(&options, 0, sizeof(options));
        options.ble_adv_fast_enabled  = true;
        options.ble_adv_fast_interval = APP_ADV_INTERVAL;
        options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
        err_code = ble_advertising_init(&advdata, &scanrsp, &options, on_adv_evt, NULL);
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
                                     APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                     bsp_event_handler);
    static void power_manage(void)
        uint32_t err_code = sd_app_evt_wait();
        uint32_t err_code;
        bool erase_bonds;
        // Initialize.
        timers_init();
        uart_init  ();
        ble_stack_init  ();
        gap_params_init ();
        services_init   ();
        advertising_init();
        conn_params_init();
    	  timers_start();
        printf("UART Start!\r\n");
        err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
        // Enter main loop.
        for (;;)
            power_manage();
  • Have you also adjusted the RAM settings to account for the increased GATT table size, i.e. allocated more RAM to the SoftDevice in the Target Settings/LInker scripts? Does sd_ble_gatts_characteristic_add return any error code? Does softdevice_enable return an error code?
  • Hi, I did not adjust anything. I already show you everything in my code. And My Ram: Start : 0x20002128 Size: 0xDED8
    and first I got error in
    then I adjust here
    that's all.
  • If you need my whole source I can email to you. Just let me know.
  • Hi guys! @vincent: I was successful to add only one more service. The problem appears when I tried to add two. But, I forgot to say that this services are custom services. This is the reason why I had to add "ble_enable_params.common_enable_params.vs_uuid_count =4", but You did not.
    Actually, the two servicis that I want to add are: ble_tcs and ble_tms from thingy project. Again, if I add only one of this services all works ok, but if I enable both at the same time as NUS, I get hardfault.
    Thanks for your code any way!
    @Bjørn Spockeli, I tried incrementing ram, as I saw in other questions, but it did'nt resolve the problem. I'm using the "debug" label in the compiler options. If I set ble_enable_params.gatts_enable_params.attr_tab_size = 5000; then I get error 4. Could you sayme what is the maxium ram config?
1 2
