I have few questions on BLE in rigado
I have few questions on BLE in rigado based on my requirement needs,
  1. I need Dynamic data transfer in beacon mode, is it possible in Beacon mode without Rigado BLE stack reset?
  2. I need to connect my device when the device is in Beacon mode, is there any possibility there to connect in Beacon mode?
  3. If above in is not possible, is there any possibility to switch between BLE normal mode to Beacon Mode without device/controller chip reset?
  4. And my system will works on coin cell battery, so is there any possibilty to switch-off/sleep-mode of BLE/BLE Radio when it is not used?
  • You are using the BMDWare that comes preloaded in the BMD300/350 correct? You better check with Rigado's tech support for all your questions above then. I also use the BMD350 but not the BMDWare i.e. the bootloader and softdevice are the same, and I load in my own application that supports scanning/advertising (beacon)/uart bridge.
