HID Consumer control settings
Dear fellow developper,
I'm trying to create a BLE device using HID service to control music, volume and so on.
I have successfully implemented a keyboard + Consumer control command in the HID service.
It works great on iOS and Android.
Now my next step since my device is not a keyboard is to remove the keyboard part and only keep the Consumer control.
So here is some of the important code :
  void hids_init()
 uint32_t                   err_code;
 ble_hids_init_t            hids_init_ob
 ble_hids_inp_rep_init_t    input_report_array[1];
 ble_hids_inp_rep_init_t  * p_input_report;
 ble_hids_outp_rep_init_t   output_report_array[1];
 ble_hids_outp_rep_init_t * p_output_report;
 uint8_t                    hid_info_flags;
memset((void *)input_report_array, 0, sizeof(ble_hids_inp_rep_init_t));
memset((void *)output_report_array, 0, sizeof(ble_hids_outp_rep_init_t));
static uint8_t report_map_data[] =
    // Report ID 2: Advanced buttons
    0x05, 0x0C,                     // Usage Page (Consumer)
    0x09, 0x01,                     // Usage (Consumer Control)
    0xA1, 0x01,                     // Collection (Application)
    0x85, 0x02,                     //     Report Id (2)
    0x15, 0x00,                     //     Logical minimum (0)
    0x25, 0x01,                     //     Logical maximum (1)
    0x75, 0x01,                     //     Report Size (1)
    0x95, 0x01,                     //     Report Count (1)
    0x09, 0xCD,                     //     Usage (Play/Pause)
    0x81, 0x02,                     //     Input (Data,Value,Relative,Bit Field)
    0x0A, 0x83, 0x01,               //     Usage (AL Consumer Control Configuration)
    0x09, 0xB5,                     //     Usage (Scan Next Track)
    0x09, 0xB6,                     //     Usage (Scan Previous Track)
    0x09, 0xEA,                     //     Usage (Volume Down)
    0x09, 0xE9,                     //     Usage (Volume Up)
    0x0A, 0x25, 0x02,               //     Usage (AC Forward)
    0x0A, 0x24, 0x02,               //     Usage (AC Back)
    0xC0                            // End Collection
// Initialize HID Service
p_input_report                      = &input_report_array[INPUT_CCONTROL_KEYS_INDEX];
p_input_report                      = &input_report_array[0];
p_input_report->max_len             = INPUT_CC_REPORT_KEYS_MAX_LEN;
p_input_report->rep_ref.report_id   = INPUT_CC_REP_REF_ID;
p_input_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_INPUT;
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_output_report->security_mode.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_output_report->security_mode.write_perm);
hid_info_flags = HID_INFO_FLAG_REMOTE_WAKE_MSK | HID_INFO_FLAG_NORMALLY_CONNECTABLE_MSK;
memset(&hids_init_obj, 0, sizeof(hids_init_obj));
hids_init_obj.evt_handler                    = on_hids_evt;
hids_init_obj.error_handler                  = service_error_handler;
hids_init_obj.is_kb                          = true;
hids_init_obj.is_mouse                       = false;
hids_init_obj.inp_rep_count                  = 1;
hids_init_obj.p_inp_rep_array                = input_report_array;
hids_init_obj.outp_rep_count                 = 1;
hids_init_obj.p_outp_rep_array               = output_report_array;
hids_init_obj.feature_rep_count              = 0;
hids_init_obj.p_feature_rep_array            = NULL;
hids_init_obj.rep_map.data_len               = sizeof(report_map_data);
hids_init_obj.rep_map.p_data                 = report_map_data;
hids_init_obj.hid_information.bcd_hid        = BASE_USB_HID_SPEC_VERSION;
hids_init_obj.hid_information.b_country_code = 0;
hids_init_obj.hid_information.flags          = hid_info_flags;
hids_init_obj.included_services_count        = 0;
hids_init_obj.p_included_services_array      = NULL;
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.rep_map.security_mode.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.rep_map.security_mode.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.hid_information.security_mode.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.hid_information.security_mode.write_perm);
    &hids_init_obj.security_mode_boot_kb_inp_rep.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_inp_rep.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.security_mode_boot_kb_inp_rep.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_outp_rep.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_outp_rep.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_protocol.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_protocol.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.security_mode_ctrl_point.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_ctrl_point.write_perm);
err_code = ble_hids_init(&m_hids, &hids_init_obj);
NRF_LOG_INFO("ERROR CODE HID INIT IS : %d \r\n", err_code);
So Now with iOS or Android I can still connect and pair my device with the bluetooth of the OS And I can also see that my OS will come automaticly register to the notification of my HID service.
But when I send one of the consumer control command like volume up or volume down, it's ignore by my smartphone.
Before with the keyboard map, it was working see below :
void hids_init()
uint32_t                   err_code;
ble_hids_init_t            hids_init_obj;
// ble_hids_inp_rep_init_t    input_report_array[2];
    0x05, 0x01,                 // Usage Page (Generic Desktop)
    0x09, 0x06,                 // Usage (Keyboard)
    0x85, 0x01,                     //     Report Id (1)
    0x05, 0x07,                 //     Usage Page (Key Codes)
    0x19, 0xe0,                 //     Usage Minimum (224)
    0x29, 0xe7,                 //     Usage Maximum (231)
    0x15, 0x00,                 //     Logical Minimum (0)
    0x25, 0x01,                 //     Logical Maximum (1)
    0x95, 0x08,                 //     Report Count (8)
    0x81, 0x02,                 //     Input (Data, Variable, Absolute)
    0x75, 0x08,                 //     Report Size (8)
    0x81, 0x01,                 //     Input (Constant) reserved byte(1)
    0x95, 0x05,                 //     Report Count (5)
    0x05, 0x08,                 //     Usage Page (Page# for LEDs)
    0x19, 0x01,                 //     Usage Minimum (1)
    0x29, 0x05,                 //     Usage Maximum (5)
    0x91, 0x02,                 //     Output (Data, Variable, Absolute), Led report
    0x75, 0x03,                 //     Report Size (3)
    0x91, 0x01,                 //     Output (Data, Variable, Absolute), Led report padding
    0x95, 0x06,                 //     Report Count (6)
    0x25, 0x65,                 //     Logical Maximum (101)
    0x05, 0x07,                 //     Usage Page (Key codes)
    0x19, 0x00,                 //     Usage Minimum (0)
    0x29, 0x65,                 //     Usage Maximum (101)
    0x81, 0x00,                 //     Input (Data, Array) Key array(6 bytes)
    0x09, 0x05,                 //     Usage (Vendor Defined)
    0x26, 0xFF, 0x00,           //     Logical Maximum (255)
    0x75, 0x08,                 //     Report Count (2)
    0x95, 0x02,                 //     Report Size (8 bit)
    0xB1, 0x02,                 //     Feature (Data, Variable, Absolute)
    0xC0,                      // End Collection (Application)
p_input_report                      = &input_report_array[INPUT_REPORT_KEYS_INDEX];
p_input_report->max_len             = INPUT_REPORT_KEYS_MAX_LEN;
p_input_report->rep_ref.report_id   = INPUT_REP_REF_ID;
p_output_report                      = &output_report_array[OUTPUT_REPORT_INDEX];
p_output_report->max_len             = OUTPUT_REPORT_MAX_LEN;
p_output_report->rep_ref.report_id   = OUTPUT_REP_REF_ID;
p_output_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_OUTPUT;
hids_init_obj.inp_rep_count                  = 2;
So I know some device that are not define as keyboard and that are working with consumer control on iOS and Android, so I guess I must miss something in my HID profile configuration ?
Especially before iOS was making sure to reconnect as fast as possible while my device was doing advertising, but keeping only the consumer control part make the OS DO NOT reconnect automaticly.
Thanks for your help.
    This report map works for me:
    I also did some changes in how the HID was initialized, and I also changed the appearance to BLE_APPEARANCE_GENERIC_HID. I tested this on SDK 14.0, and it works fine on Android version 7.
    See attached main.c file.
    Attachment: main.c
  • @Sigurd I tried as you said not working with iOS. Still searching for the solution =)
