nRF52832 system powers off and wakes up it
Hi everyone,
I am developing a remote control using nRF52832 chip. My prototype is currently developed in PC10040 board. The IDE is Eclipse Oxygen, and the SDK is S132 v5.0.0.
I am trying to power off my system using NRF_POWER->SYSTEMOFF = 0x01; when I press a button and then, by pressing that button again, the system will wake up and cause a reset. The problem is when I press the button for the first time, the system seems to reset unstoppable, even when I press the reset button or turn off and then turn on the power again, it is still reset continuosly.
Could you help me please? Thanks
  • Well we will hardly help you not knowing what exactly you do in your code before you try to send the chip to SYSTEM OFF. E.g. if you are using Nordic BLE stack and Soft Device is enabled you cannot write to these registers directly but use dedicated sd_power_system_off() function as per API description. Note that this isn't magic cure to every problem with SYSTEM OFF mode, you need to take care about initialization/deinitialization of some things (at least that's my experience). Also for wake-up you need to set the PIN specifically. Have you seen the power management example from nRF5 SDK? Can you make your application working in the same way before even using BLE stack (Soft Device)? Only then you should try to achieve the same flow but with BLE stack enabled.
  • Hi endnode, I enable BLE stack before I power off the system using NRF_POWER->SYSTEMOFF = 0x01;. I have tried comment out the BLE stack config and enable codes, but the problem still happens :((( Below is my piece of code I use to config the system:
     * @brief : Config system
     * @param :
     * @return:
    void ConfigSystem()
        // Config Log
        ConfigLog(TX_PIN_NUMBER, RX_PIN_NUMBER, CTS_PIN_NUMBER, RTS_PIN_NUMBER, HWFC, UART_BAUDRATE_115200);
        Print("\n\n\n");
        PrintInfo("Headset for people with low vision project");
        PrintAppInfo("Log Initialized!");
        // Config SPI
        // USE_SPI have to be defined if SPI is used
    #ifdef USE_SPI
        SPIConfig.SPIBase = NRF_SPIM0;
        SPIConfig.pinCSN = CSN_PIN_NUMBER;
        SPIConfig.pinSCK = SCK_PIN_NUMBER;
        SPIConfig.pinMOSI = MOSI_PIN_NUMBER;
        SPIConfig.pinMISO = MISO_PIN_NUMBER;
        SPIConfig.role = SPI_ROLE;
        SPIConfig.mode = SPI_MODE;
        SPIConfig.order = SPI_BIT_ORDER;
        SPIConfig.freq = SPIM_FREQ_M8;
        ConfigSPI(SPIConfig);
        PrintAppInfo("SPI Master Initialized!");
        // Config I2C
        // USE_I2C have to be defined if I2C is used
    #ifdef USE_I2C
        I2CMasterConfig.I2CBase = NRF_TWIM0;
        I2CMasterConfig.pinSCL = SCL_PIN_NUMBER;
        I2CMasterConfig.pinSDA = SDA_PIN_NUMBER;
        I2CMasterConfig.role = I2C_ROLE;
        I2CMasterConfig.frequency = I2CM_FREQ_K100;
        ConfigI2C(I2CMasterConfig);
        PrintAppInfo("I2C Master Initialized!");
        // Config indicators (GPIO pins used for controlling LEDs)
        ConfigIndicator();
        PrintAppInfo("Indicator Initialized!");
        //Config ADC
        ADC_Channel_Configuration_t ADCChannelConfig;
        ADCChannelConfig.ADCPosPin = ADC_PSELP_PIN;
        ADCChannelConfig.ADCNegPin = ADC_PSELN_PIN;
        ADCChannelConfig.resPinPos = ADC_RESISTOR_DISABLED;
        ADCChannelConfig.resPinNeg = ADC_RESISTOR_PULLDOWN;
        ADCChannelConfig.acqTime = ADC_ACQTIME_3US;
        ADCChannelConfig.burst = ADC_BURST_DISABLED;
        ADCChannelConfig.gain = ADC_GAIN_1_6;
        ADCChannelConfig.mode = ADC_MODE_DIFF;
        ADCChannelConfig.reference = ADC_REFERENCE_INTERNAL;
        ConfigADCChannel(ADC_CHANNEL, ADCChannelConfig);
        ADC_Configuration_t ADCConfig;
        ADCConfig.resolution = ADC_RESOLUTION;
        ADCConfig.samplerateMode = ADC_SAMPLERATE_MODE_TASK;
        ADCConfig.oversample = ADC_OVERSAMPLE_DISABLED;
        ADCConfig.buffer = &ADCBuffer;
        ADCConfig.bufferAmount = 1;
        ConfigADC(ADCConfig);
        PrintAppInfo("ADC Initialized!");
        // Config BLE and start advertising
        ConfigBLE();
        PrintAppInfo("BLE Initialized!");
        //  BLEStartAdvertising(BLE_ADV_MODE_FAST);
        //  PrintAppInfo("Start advertising");
        BLEStartScanning();
        PrintAppInfo("Start scanning");
        // Config Power
        ConfigPOWER();
        PrintAppInfo("POWER Initialized!");
        // delay a while for system to be ready
        int i;
        for(i = 0; i < 1000; i++)
     * @param :
     * @return:
    void ConfigSystem()
        // Config Log
        Print("\n\n\n");
        // Config SPI
    #ifdef USE_SPI
        // Config I2C
    #ifdef USE_I2C
        ConfigIndicator();
        //Config ADC
        ConfigBLE();
        BLEStartScanning();
        // Config Power
        ConfigPOWER();
        int i;
