PA and LNA on nrf51822
Hi, is it possible to add for example a www.ti.com/.../technicaldocuments On the nrf51822? I would have to modify the S110 source to turn on and off the LNA and PA when needed.
Would this be a viable solution in extending the range of the nrf51822? Do you have any other tip or idea on how to extend the range?
Parents Reply
  • I'm glad to hear that you find the forum useful :-) The VDD_PA pin on the nRF should be connected to the ENABLE pin of the RFPA. This will enable the RFPA to go into a "throughput mode" when disabled, so that the RX signal can go into the radio.
    Additional information: The BALUN (or matching network) works both ways. For a transmission, it converts the differential output from the nRF to a single-ended signal. For a reception, it converts the single-ended input into differential signal.
