Issue using NRF_DRV_TWI_XFER_DESC_TXRX TWI master driver
At the very end of this post from Nordic Info center I am doing the exact example at the very end.
infocenter.nordicsemi.com/index.jsp
This is the start to do a transmit read transaction ===>
nrf_drv_twi_xfer_desc_t xfer = NRF_DRV_TWI_XFER_DESC_TXRX(addr, p_tx_buffer, tx_length, p_rx_buffer, rx_length);
ret_code_t ret = nrf_drv_twi_xfer(&twi, &xfer, 0);
if (ret == NRF_SUCCESS)
  while(xfer_completed == false){}
This is the end to verify the transfer worked successfully =======>
void twi_event_handler(nrf_drv_twi_evt_t * p_event, void * p_context)
    if ((p_event->type == NRF_DRV_TWI_EVT_DONE) &&
    (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_TXRX))
    { xfer_completed = true; }
My issue is this, I can do this once successfully, then when I do it again, the event_handler never gets called and I have to unititalize and then initialize the TWI module again, then it will repeat this, will work once then not the second time until I re initialize the TWI bus.
