EVENT_ADDRES and EVENT_END timing on coded phy
The tx/rx sequence diagrams don't explain when EVENT_ADDRESS and EVENT_END are triggered when using coded phy:
  • there are CI and TERM1 fields between address and S0 so EVENT_ADDRESS is generated directly after address or directly before S0?
  • there is TERM2 field at the end of packed so EVENT_END is generated after CRC or after TERM2?
Also I assume these events are generated at the same place for both TX and RX, aren't they?
