Problems managing a buffer to track events to the ble stack
I am using the following code to manage a buffer to put through data to the ble stack. I think I saw a similar code on the nRFready Desktop 2 v1.0.4 examples:
/**@brief Packet buffering initialization
static void buffer_init(void)
    uint32_t err_code;
    memset(&s_packet_buffer, 0, sizeof(s_packet_buffer));
		err_code = sd_ble_tx_buffer_count_get (&s_packet_buffer.sd_buffers_available);
		ASSERT(err_code == NRF_SUCCESS);
    err_code =  app_timer_create(&s_packet_buffer_id,
                                  APP_TIMER_MODE_REPEATED,
                                  buffer_send_handler);
/**@brief Timeout function used when packet buffer is not empty
static void buffer_send_handler(void* p_context)
    uint32_t err_code;
    // Clear buffer and stop handler if not connected
		if (s_connection_state != state_connected)
				s_packet_buffer.nb_packets = 0;			// Clear buffer
				app_timer_stop(s_packet_buffer_id);		// Stop handler time
        return;
		else if (s_connection_state == state_advertising)
			// Already advertising and waiting for a conenction
			return;
		while ((s_packet_buffer.nb_packets))
			#if defined(DEBUG_UART_MAIN)
				printf("B-L\tB:%u\r\n",s_packet_buffer.sd_buffers_available);
			if (s_packet_buffer.sd_buffers_available > MIN_SD_BUFFERS_AVAILABLE)
				memcpy (poster_value, &s_packet_buffer.buffer[s_packet_buffer.index], MIDI_MAX_PACKET_LEN);
				err_code = poster_value_meas_handler();
				if (err_code == NRF_SUCCESS)
							printf("B-S\r\n");
						s_packet_buffer.nb_packets--;
						s_packet_buffer.sd_buffers_available--;
						s_packet_buffer.index = ((s_packet_buffer.index + 1) % SCHED_QUEUE_SIZE);
							printf("SE:%u\r\n",err_code);
					return;
			if (s_packet_buffer.nb_packets == 0)
					return;
/**@brief Utility function to buffer packets that fails to be sent
static void buffer_data(const midi_packet_t* packet)
	 // The m_coms_btle module should start advertising if data is needed to be send
	if (s_connection_state == state_disconnected)
			// Start advertising if we are not connected
			s_connection_state = state_advertising;
			advertising_start();
			return;
		return;
	if (s_packet_buffer.nb_packets == SCHED_QUEUE_SIZE)
		 // Buffer is full. Won't overwrite.
		 return;
			uint32_t index;
			index = (s_packet_buffer.index + s_packet_buffer.nb_packets) %
							(sizeof(s_packet_buffer.buffer) / sizeof(s_packet_buffer.buffer[0]));
			// Put the packet in our circular buffer
			memcpy(&s_packet_buffer.buffer[index], packet, sizeof(midi_packet_t));
			s_packet_buffer.nb_packets++;
			// Start the timeout handler
			app_timer_start(s_packet_buffer_id, APP_TIMER_TICKS(15 /* [ms] */, APP_TIMER_PRESCALER), 0);
This should keep track of the packet buffers in use on the ble stack and only send new ones when there is available room for a new packet. The number of buffers available (s_packet_buffer.sd_buffers_available) is incremented every time a BLE_EVT_TX_COMPLETE event is received as follows:
case BLE_EVT_TX_COMPLETE:
						s_packet_buffer.sd_buffers_available += p_ble_evt->evt.common_evt.params.tx_complete.count;
							printf("M-TXC:%u\r\n",p_ble_evt->evt.common_evt.params.tx_complete.count);
I have add some lines to debug through uart. This is the ouput (BE are bluetooth events)
Modules Initialized
BE: 0x0010
BE: 0x0052
BE: 0x0050
BE: 0x0050
BE: 0x0050
BE: 0x0012
B-L     B:7
B-S
B-L     B:6
B-S
M-TXC:1
BE: 0x0001
B-L     B:6
B-S
B-L     B:5
B-S
M-TXC:2
BE: 0x0001
B-L     B:6
B-S
B-L     B:5
B-S
B-L     B:4
B-S
B-L     B:3
B-S
M-TXC:3
BE: 0x0001
B-L     B:5
B-S
B-L     B:4
B-S
B-L     B:3
B-S
M-TXC:1
BE: 0x0001
M-TXC:1
BE: 0x0001
B-L     B:4
B-S
B-L     B:3
B-S
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
B-L     B:2
It may be sth basic that I can't see, but it seems that packets are send to the ble stack but not all are cleared through a BLE_EVT_TX_COMPLETE event. Any ideas? Any suggestion?
Thanks in advance
  • Hi Ignaco,
    I am sorry indeed for the late response.
    Could you provide poster_value_meas_handler() function ? It's pretty strange to see this behaviour. I had previously tested with BLE_EVT_TX_COMPLETE and p_ble_evt->evt.common_evt.params.tx_complete.count but hadn't seen this issue.
    It could be that some packets hadn't buffered correctly that made the buffer count (sd_buffers_available) went wrong.
    On the central side, do you receive all the packet you queued ? You can track which packet was missing when the buffer count stuck at 2.
    Thanks for your reply.
    This is the poster_value_meas_handle function:
    static uint32_t poster_value_meas_handler(void)
    	uint32_t        err_code;
    	err_code = ble_pos_poster_value_measurement_send(m_pos, poster_value);
    	return err_code;
    And the ble_pos_poster_value_measurement_send function. It is our own profile and it based on the heart rate profile with some modifications:
    uint32_t ble_pos_poster_value_measurement_send(ble_pos_t * p_pos, uint8_t *poster_value)
        uint32_t err_code;
        // Send value if connected and notifying
        if (p_pos->conn_handle != BLE_CONN_HANDLE_INVALID)
            uint16_t               len;
            uint16_t               hvx_len;
            ble_gatts_hvx_params_t hvx_params;
    				len = poster_value[0] + 1;	// packet length is poster data size plus length byte
            hvx_len = len;
            memset(&hvx_params, 0, sizeof(hvx_params));
            hvx_params.handle   = p_pos->pos_handles.value_handle;
            hvx_params.type     = BLE_GATT_HVX_NOTIFICATION;
            hvx_params.offset   = 0;
            hvx_params.p_len    = &hvx_len;
            hvx_params.p_data   = poster_value;
            err_code = sd_ble_gatts_hvx(p_pos->conn_handle, &hvx_params);
            if ((err_code == NRF_SUCCESS) && (hvx_len != len))
                err_code = NRF_ERROR_DATA_SIZE;
            err_code = NRF_ERROR_INVALID_STATE;
        return err_code;
    Yes, I receive all the packets that I am sending on Master Control Panel.
