GPIO IN_EVENT to GPIO PORT Event
Hello, I'm new to Nordic SDK and I would like to ask you for help with change of GPIO IN_EVENT to GPIO PORT event implementation. The reason is we are using revision < 3 and I need to decrease power consumption.
Current implementation is like following:
void init_gpio_button()
    nrf_gpio_cfg_input(GPIO_BUTTON, NRF_GPIO_PIN_PULLUP);
	uint32_t err_code = nrf_drv_gpiote_init();
    nrf_drv_gpiote_in_config_t btn = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
	btn.pull = NRF_GPIO_PIN_PULLUP;
	nrf_drv_gpiote_in_uninit(GPIO_BUTTON);
	err_code = nrf_drv_gpiote_in_init(GPIO_BUTTON, &btn, btn_handler_isr);
	nrf_drv_gpiote_in_event_enable(GPIO_BUTTON, true);
Is it enough to just set GPIOTE_CONFIG_IN_SENSE_HITOLO.hi_accuracy = false?
Thank you very much for your help.
    Yes, if you set the .hi_accuracy flag to true, then the GPIOTE will use IN event(consumes more current), but if you set the flag to false, the GPIOTE will use the PORT event (low accuracy mode, uses less current.) You don't need to configure anything more than that, the GPIOTE driver takes care of the rest.
  • PS: If you need to decrease power consumption, take a look at this post.
  • Thank you I will have a look on the post.
    I have one more question. In case I have more than one input GPIOs, how the interrupt handling must be changed? In our implementation we have 4 input GPIOs and if change .hi_accuracy to false for all four GPIOs after I receive first interrupt, I don't receive any else. Do I need to clear any interrupt flag?
    Thank you very much.
  • You should not need to clear any interrupt flag yourself, the GPIOTE driver should take care of that for you.
    Could you post your init_gpio_button() function where you use 4 inputs GPIOs ?
  • First function is the one mentioned in the initial question. It's also called first. Next three init functions are following:
    void init_gpio_acc()
      ret_code_t err_code;
      nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(false);
      in_config.pull = NRF_GPIO_PIN_NOPULL;
      err_code = nrf_drv_gpiote_in_init(GPIO_AINT1, &in_config, pin_handler);
      nrf_drv_gpiote_in_event_enable(GPIO_AINT1, false);
    void int_gpio_gyro()
      err_code = nrf_drv_gpiote_in_init(GPIO_GINT1, &in_config, pin_handler);
      nrf_drv_gpiote_in_event_enable(GPIO_GINT1, false);
    void int_gpio_comm()
      nrf_drv_gpiote_in_config_t dio0 = GPIOTE_CONFIG_IN_SENSE_LOTOHI(false);
      dio0.pull = NRF_GPIO_PIN_NOPULL;
      nrf_drv_gpiote_in_uninit(GPIO_DIO0);
      err_code = nrf_drv_gpiote_in_init(GPIO_DIO0, &dio0, dio_handler_isr);
      nrf_drv_gpiote_in_event_enable(GPIO_DIO0, true);
    If I use .hi_accuracy set to true the functionality is fine. When I change it to false I receive just one interrupt and that's all.
    Thank you for comment.
1 2
