nRFConnect iOS and Windows see different modified DEVICE_NAME
I have modified my device name (nRF52, BLE) per the function below. When flashed to a board, I then use nRF connect to look for this device.
Using Windows nRFConnect and the nRF52 dongle, the name is "JK_BXY". Using iPhone and nRFConnect, the name is "JUNK_BL". These are scanning the same device at the same time!
I have just started to try and understand how this could be, but it seems that the iOS BLE communication must do something different such that the gap_params_init isn't called or is later overridden. But i cannot find another function that does this (overrides).
The only apparent place sd_ble_gap_device_name_set(...) is called is in this function, which clearly only calls out the modified name.
Does anyone have any suggestions on where to look?
static uint32_t gap_params_init(void)
    uint32_t                err_code;
    ble_gap_conn_params_t   gap_conn_params = {0};
    err_code = gap_address_change();
    VERIFY_SUCCESS(err_code);
#if (1)
		/* Change name from JUNK_BL which is the define DEVICE_NAME */
		uint8_t devname[6] = {'J','K','_','B','X','Y'};
                                          (const uint8_t *)devname,
                                          7);
#else
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    return err_code;
