How to make beacon connectable
Hi Nordic,
I am trying to implement DFU-OTA in beacon. For that I am trying to make beacon connectable. My requirement is to work the beacon in non-connectable mode during normal operation whereas for implementing DFU, I need to make it connectable by using a button press.
What I have implemented - when a button is pressed, I stop the advertising and start the connectable advertising.
Issue faced- I am not able to perform DFU. My reasoning is that, since I have copied the DFU relevant code snippets from working example code, there is nearly no chance of error in DFU part. So I am guessing the issue lies with transition from non-connectable to connectable mode.
Is my implementation for connectable mode correct?If there is a better way of implementing the following, please suggest..
  • Hi Hung, Thanks.I debugged the problem. The issue was due to the advertising init function called inside the for loop. Although the device switched from non-connectable to connectable mode,before the whole transition, it jumped back to non-connectable mode due to the advertising init function. It worked fine after I prevented the following by using a flag variable.
