Code works with nothing in sdk_config.h enabled
I'm a little confused here...I have a basic main function which is turning on/off some GPIO and logging through SEGGER_RTT.
I thought that in order for that to work, you need to enable the logging defines in the sdk_config.h. However, I've disabled everything in the sdk_config.h file and it still outputs data out of RTT. See code below. Can someone help me understand what the point of the sdk_config.h is if it doesn't seem to do anything?
   // Standard include files
    #include <stdbool.h>
    #include <stdint.h>
    // Include nRF HAL headers here
    #include "nrf_delay.h"
    #include "nrf_gpio.h"
    #include "nrf_power.h"
    #include "nrf_clock.h"
    // Include nRF libraries here
    #include "SEGGER_RTT.h"
        	// Initialize GPIO
        	SEGGER_RTT_WriteString(0, "Initializing...\n");
        	nrf_gpio_cfg_output(RED_LED_PIN);
        	nrf_gpio_cfg_output(YELLOW_LED_PIN);
        	nrf_gpio_cfg_input(ACCEL_INT1_PIN, NRF_GPIO_PIN_PULLUP);
        	nrf_gpio_cfg_input(ACCEL_INT2_PIN, NRF_GPIO_PIN_PULLUP);
        	nrf_gpio_cfg_input(BUTTON_PIN, NRF_GPIO_PIN_PULLUP);
        	// Turn LEDs on
        	nrf_gpio_pin_set(RED_LED_PIN);
        	nrf_gpio_pin_set(YELLOW_LED_PIN);
            while (true)
        		test = nrf_gpio_pin_read(ACCEL_INT1_PIN);
        		test2 = nrf_gpio_pin_read(ACCEL_INT2_PIN);
        		test3 = nrf_gpio_pin_read(BUTTON_PIN);
        		SEGGER_RTT_WriteString(0, "Printing input values:\n");
        		SEGGER_RTT_printf(0, "%d\n", test);
        		SEGGER_RTT_printf(0, "%d\n", test2);
        		SEGGER_RTT_printf(0, "%d\n", test3);
        		nrf_delay_ms(1000);
  • You don't need to enable RTT through sdk_config.h if you are using the RTT functions directly instead of nrf_log functions.
  • If you want to do logging, I would recommend using NRF_LOG. This will allow you to easily enable/disable logging for separate modules, possiblity to change logging level, and many other features. Please see the library documentation for more details. If you only want to print a few lines, using RTT directly is OK.
