Is S212 compatible with DK52?
Hi
On www.nordicsemi.com/.../nRF52-DK is only written S132, but I want to use nRF52DK with S212 (Ant stack) - is this possible?
Thanks
  • Yes - use the 'Resources' tab above and click the nRF52 series and then softdevices and you'll see S212 which, if you open that, says
    S212 SoftDevice
    The S212 SoftDevice is an ANTTm protocol stack solution that provides a full and flexible Application Programming Interface (API) for building ANT System on Chip (SoC) solutions for the nRF52832 chip. The S212 SoftDevice simplifies combining the ANT protocol stack and an application on the same CPU.
    The S212 SoftDevice is provided by Dynastream in collaboration with Nordic Semiconductor.
    S212 SoftDevice API
    The SoftDevice API documentation is available for different versions of the SoftDevice.
    I think you have to get the softdevice from dynastream directly now and there are license fees for using it (the licensing used to be bundled into the cost of the nrf51422 chip but isn't with the 52 series).
  • Ok, I see. Thanks for your support.
