SDK 14.0 no events received
I am in the process of porting my code from SDK13.0 to 14.0 in order to use s332 v5.0
I can compile and run my application. While it's running, I can see that it is sending out BLE advertisements and that it is sending out ANT messgaes (although at a lower rate than expected).
However, I don't seem to receive any events that are now done via observers e.g.
NRF_SDH_BLE_OBSERVER(m_ble_observer, APP_BLE_OBSERVER_PRIO, ble_evt_dispatch, NULL);
This means that I can't connect to my device or have it connect to other devices.
What could I be missing? I see the same behaviour when using s132 v5.0
Edit 4 Oct 2017 I played around a bit and added nrf_drv_clock rather where i was previously using sd_clock_hfclk_request();
I've replaced the ble_stack_init in the ble_app_hrs example with my settings, as shown below, and I don't have any issues. In my application I still don't get any events to observers, which now gives me issues with nrf_sdh_enable_request returning NRF_ERROR_SDM_INCORRECT_INTERRUPT_CONFIGURATION because the nrf_drv_clock driver won't receive a NRF_SDH_EVT_STATE_ENABLE_PREPARE event. // nRF_SoftDevice
// <e> NRF_SDH_BLE_ENABLED - nrf_sdh_ble - SoftDevice BLE event handler
#ifndef NRF_SDH_BLE_ENABLED
#define NRF_SDH_BLE_ENABLED 1
// <h> BLE Stack configuration - Stack configuration parameters
// <i> These values are not used directly by the SoftDevice handler but the application or other libraries might depend on them.
// <i> Keep them up-to-date with the desired configuration.
// <o> NRF_SDH_BLE_PERIPHERAL_LINK_COUNT - Maximum number of peripheral links.
#ifndef NRF_SDH_BLE_PERIPHERAL_LINK_COUNT
#define NRF_SDH_BLE_PERIPHERAL_LINK_COUNT 5
// <o> NRF_SDH_BLE_CENTRAL_LINK_COUNT - Maximum number of central links.
#ifndef NRF_SDH_BLE_CENTRAL_LINK_COUNT
#define NRF_SDH_BLE_CENTRAL_LINK_COUNT 8
// <o> NRF_SDH_BLE_TOTAL_LINK_COUNT - Maximum number of total concurrent connections using the default configuration.
#ifndef NRF_SDH_BLE_TOTAL_LINK_COUNT
#define NRF_SDH_BLE_TOTAL_LINK_COUNT 13
// <o> NRF_SDH_BLE_GAP_EVENT_LENGTH - The time set aside for this connection on every connection interval in 1.25 ms units.
#ifndef NRF_SDH_BLE_GAP_EVENT_LENGTH
#define NRF_SDH_BLE_GAP_EVENT_LENGTH 3
// <o> NRF_SDH_BLE_GATT_MAX_MTU_SIZE - Static maximum MTU size.
#ifndef NRF_SDH_BLE_GATT_MAX_MTU_SIZE
#define NRF_SDH_BLE_GATT_MAX_MTU_SIZE 27
// <o> NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE - Attribute Table size in bytes. The size must be a multiple of 4.
#ifndef NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE
#define NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE 1408
// <o> NRF_SDH_BLE_VS_UUID_COUNT - The number of vendor-specific UUIDs.
#ifndef NRF_SDH_BLE_VS_UUID_COUNT
#define NRF_SDH_BLE_VS_UUID_COUNT 5
// <q> NRF_SDH_BLE_SERVICE_CHANGED  - Include the Service Changed characteristic in the Attribute Table.
#ifndef NRF_SDH_BLE_SERVICE_CHANGED
#define NRF_SDH_BLE_SERVICE_CHANGED 1
// </h>
    ret_code_t err_code;
    nrf_drv_clock_init();
    nrf_drv_clock_hfclk_request(NULL);
    while (!nrf_drv_clock_hfclk_is_running())
    uint32_t ram_start = 0;
    err_code = nrf_sdh_ble_app_ram_start_get(&ram_start);
    ble_cfg_t ble_cfg;
    memset(&ble_cfg, 0, sizeof(ble_cfg));
    ble_cfg.gap_cfg.role_count_cfg.periph_role_count  = NRF_SDH_BLE_PERIPHERAL_LINK_COUNT;
    ble_cfg.gap_cfg.role_count_cfg.central_role_count = NRF_SDH_BLE_CENTRAL_LINK_COUNT;
    ble_cfg.gap_cfg.role_count_cfg.central_sec_count  = ((NRF_SDH_BLE_CENTRAL_LINK_COUNT > 0) ? 1 : 0); //ble_connection_manager serialises central connections so we only need 1 Security manager instance
    err_code = sd_ble_cfg_set(BLE_GAP_CFG_ROLE_COUNT, &ble_cfg, ram_start);
    ble_cfg.common_cfg.vs_uuid_cfg.vs_uuid_count = NRF_SDH_BLE_VS_UUID_COUNT;
    err_code = sd_ble_cfg_set(BLE_COMMON_CFG_VS_UUID, &ble_cfg, ram_start);
    ble_cfg.gatts_cfg.service_changed.service_changed = NRF_SDH_BLE_SERVICE_CHANGED;
    err_code = sd_ble_cfg_set(BLE_GATTS_CFG_SERVICE_CHANGED, &ble_cfg, ram_start);
    if(NRF_SDH_BLE_CENTRAL_LINK_COUNT > 0)
        ble_cfg.conn_cfg.params.gap_conn_cfg.conn_count     = NRF_SDH_BLE_CENTRAL_LINK_COUNT;
        ble_cfg.conn_cfg.params.gap_conn_cfg.event_length   = BLE_GAP_EVENT_LENGTH_DEFAULT;
        ble_cfg.conn_cfg.conn_cfg_tag                       = CENTRAL_BLE_CONN_CFG_TAG;
        err_code = sd_ble_cfg_set(BLE_CONN_CFG_GAP, &ble_cfg, ram_start);
        ble_cfg.conn_cfg.params.gatt_conn_cfg.att_mtu = BLE_GATT_ATT_MTU_DEFAULT;
        err_code = sd_ble_cfg_set(BLE_CONN_CFG_GATT, &ble_cfg, ram_start);
    // Peripheral connections specific parameters
    ble_cfg.conn_cfg.params.gap_conn_cfg.conn_count     = NRF_SDH_BLE_PERIPHERAL_LINK_COUNT;
    ble_cfg.conn_cfg.conn_cfg_tag                       = PERIPH_BLE_CONN_CFG_TAG;
    ble_cfg.conn_cfg.params.gatt_conn_cfg.att_mtu = NRF_SDH_BLE_GATT_MAX_MTU_SIZE;
    ble_cfg.conn_cfg.params.gatts_conn_cfg.hvn_tx_queue_size = 30;
    err_code = sd_ble_cfg_set(BLE_CONN_CFG_GATTS, &ble_cfg, ram_start);
    ble_cfg.gatts_cfg.attr_tab_size.attr_tab_size = BLE_GATTS_ATTR_TAB_SIZE_DEFAULT;
    err_code = sd_ble_cfg_set(BLE_GATTS_CFG_ATTR_TAB_SIZE, &ble_cfg, ram_start);
    // Enable BLE stack.
