I am using the nrf52832 with SDK v12.3 and PCA10040. Not using any soft devices, nor the RTC. The program is intended such thattimer0
is set to toggle a pin (P0_11) every 166us using 1MHz clock source and timer2
is set to toggle another pin (P0_08) every 1us also using the 1MHz clock source. timer0
is working properly toggling every 166us but timer2
is toggling every 2.6us when it should be toggling every 1us according to my settings.
In sdk_config.h, I have:
// <e> TIMER_ENABLED - nrf_drv_timer - TIMER periperal driver
#ifndef TIMER_ENABLED
#define TIMER_ENABLED 1
// <q> TIMER0_ENABLED - Enable TIMER0 instance
#ifndef TIMER0_ENABLED
#define TIMER0_ENABLED 1
// <q> TIMER1_ENABLED - Enable TIMER1 instance
#ifndef TIMER1_ENABLED
#define TIMER1_ENABLED 0
// <q> TIMER2_ENABLED - Enable TIMER2 instance
#ifndef TIMER2_ENABLED
#define TIMER2_ENABLED 1
// <q> TIMER3_ENABLED - Enable TIMER3 instance
#ifndef TIMER3_ENABLED
#define TIMER3_ENABLED 0
// <q> TIMER4_ENABLED - Enable TIMER4 instance
#ifndef TIMER4_ENABLED
#define TIMER4_ENABLED 0
in main.c, I have the following:
#include <stdbool.h>
#include <stdint.h>
#include "nrf.h"
#include "nrf_drv_timer.h"
#include "nrf_timer.h"
#include "nrf_gpio.h"
//timer0
const nrf_drv_timer_t timer0 = NRF_DRV_TIMER_INSTANCE(0);
//timer2
const nrf_drv_timer_t timer2 = NRF_DRV_TIMER_INSTANCE(2);
nrf_drv_timer_config_t timer_cfg2 = NRF_DRV_TIMER_DEFAULT_CONFIG;
uint32_t err_code = NRF_SUCCESS;
//timer0 test pin
nrf_gpio_cfg_output(P0_11);
//timer2 test pin
nrf_gpio_cfg_output(P0_08);
//change config from defaults in NRF_DRV_TIMER_DEFAULT_CONFIG for timer0
timer_cfg.frequency = NRF_TIMER_FREQ_1MHz;
timer_cfg.bit_width = NRF_TIMER_BIT_WIDTH_8;
//change config from defaults in NRF_DRV_TIMER_DEFAULT_CONFIG for timer2
timer_cfg2.frequency = NRF_TIMER_FREQ_1MHz;
timer_cfg2.bit_width = NRF_TIMER_BIT_WIDTH_32;
//initialize timer0 with config changes and event handler
err_code = nrf_drv_timer_init(&timer0, &timer_cfg, timer0_event_handler);
//initialize timer2 with config changes and event handler
err_code = nrf_drv_timer_init(&timer2, &timer_cfg2, timer2_event_handler);
//set ticks for timer0
uint32_t timer0_ticks = 166;
//set timer0 operating mode
nrf_drv_timer_extended_compare(&timer0, NRF_TIMER_CC_CHANNEL0, timer0_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
//set ticks for timer2
uint32_t timer2_ticks = 1;
//set timer2 operating mode
nrf_drv_timer_extended_compare(&timer2, NRF_TIMER_CC_CHANNEL0, timer2_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
//enable timer0
nrf_drv_timer_enable(&timer0);
//enable timer2
nrf_drv_timer_enable(&timer2);
while(1)
__WFI();
