Waking when app_sched_event_put() is called from main context
Most application examples which use the scheduler have a main loop looking something like this,
    // Initialization <snipped>
    // Enter main loop.
    for (;;)
    	app_sched_execute();
            ret_code_t err_code = sd_app_evt_wait();  // or __WFE() if no soft device is used
Clearly if an interrupt routine pushes an event using app_sched_event_put() then the application will wake from sd_app_event_wait() and the event handler will be executed when the main loop calls app_sched_execute().
What happens though if the main loop itself (or an event handler executing in the main context via an app_sched_execute() call) pushes an event to the queue but no subsequent interrupt occurs? Does the application then remain asleep with the pushed event stuck in the queue?
I assume this is the case, but just wanted to confirm, as it suggests perhaps using a timer to periodically schedule execution of a "master" application event hander / state machine which then processes events (e.g., bit-flags) set by the various app_sched_execute()'ed handlers.
Thanks!
