I was wondering whether or not it's possible to achieve a data rate of 160Kbps using BLE4.2. According to what I have read on this nordic blog it should be feasable, since there the maximum throughput is stated as 775 Kbps for BLE 4.2
Running the example of ble_app_att_mtu_throughput I can see how the throughput there depicted when setting an extended mtu to 158Bytes along with enabling event length extended is around 465Kbps, so seeing this I could achieve the same for my application.
However, I have some questions, the first one is regarding to setting a mtu of 158Bytes, I see that this is done a GATT level so and exachange of the used MTU(between Pheripherial and Central) has to happen each time that a transmission will occur or that is what I see on the example, is that so? I mean the extension of the MTU is only controlled at GATT level?
My second questions is related to the timing, since I would like to send a large data rate, what are the best ble connection parameters to achieve this? I mean, parameters such as CONN_INTERVAL_DEFAULT,CONN_INTERVAL_MIN and CONN_INTERVAL_MAX.
FInally, should I use the setting ble_conn_bw_toffered on the bandwidth configuration of BLE ble_common_opt_conn_bw_t if I enable an extended mtu and event length extended?
Thanks in advance,
