nrf_dfu_mbr_init_sd blocking bootloader after reset?
Hej allesammen!
I'm having trouble with the bootloader example "bootloader_secure_ble", which seems to stuck when calling nrf_dfu_mbr_init_sd. But one thing after another:
preconds: using nRF5_SDK_13.0.0, Segger embedded studio 3.26
bootloader_secure_ble has been ported by me to SES, using Bjørn's memory map and flash allocation examples from here
now, if I flash SD+MBR first like that:
nrfjprog.exe --program s132_nrf52_4.0.2_softdevice.hex -f nrf52 --chiperase
And then program the bootloader:
nrfjprog.exe --reset --program myBootloader.hex --sectoranduicrerase -f nrf52
nrfjprog does its job, resets and runs the bootloader at the end. Bootloader works as expected, I can update an application using nrf Connect and it will even be executed after a reset. I can even do a soft-reset using nrfjprog -r and the bootloader is still working.
BUT If I do a hard-reset using reset button (or cutting power), the bootloader will run but it seems getting stuck somewhere around that nrf_dfu_mbr_init_sd With enabled logging, output looks like this when working well (just after flashing as explained above):
 0> :INFO:Inside main
 0> :DEBUG:In nrf_bootloader_init
 0> :DEBUG:In real nrf_dfu_init
 0> :DEBUG:running nrf_dfu_settings_init
 0> :DEBUG:Enter nrf_dfu_continue
 0> :ERROR:Single: Invalid bank
 0> :DEBUG:Application sent bootloader request
 0> :DEBUG:In nrf_dfu_transports_init
 0> :DEBUG:num transports: 1
 0> :DEBUG:vector table: 0x0006e000
 0> :DEBUG:Error code - sd_softdevice_vector_table_base_set: 0x00000000
 0> :DEBUG:Before SOFTDEVICE_HANDLER_APPSH_INIT
 0> :DEBUG:After SOFTDEVICE_HANDLER_APPSH_INIT
 0> :INFO:Error code - sd_ble_cfg_set: 0x00000000
 0> :DEBUG:Enabling softdevice.
 0> SDH:DEBUG:RAM start at 0x20002100.
 0> SDH:WARNING:RAM start should be adjusted to 0x20002060.
 0> SDH:WARNING:RAM size should be adjusted to 0xdfa0.
 0> :DEBUG:Softdevice enabled
 0> :DEBUG:After nrf_dfu_transports_init
 0> :DEBUG:nrf_dfu: init dfu req handler:DEBUG:------- nrf_dfu_flash_init-------
 0> :DEBUG:Waiting for events
and after a reset of any kind, looks like that:
and obviously, no normal bootloader operation anymore. It seems as if it got stuck somewhere somehow. Trying to locate where it got stuck pointed me to that nrf_dfu_mbr_init_sd called at line 827 in ble_stack_init in file nrf_ble_dfu.c :
uint32_t           err_code;
nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
if (init_softdevice)
    err_code = nrf_dfu_mbr_init_sd();
    VERIFY_SUCCESS(err_code);
NRF_LOG_DEBUG("vector table: 0x%08x\r\n", BOOTLOADER_START_ADDR);
The documentation about nrf_dfu_mbr_init_sd leaves me still clueless and the reason for above boolean switch "init_softdevice" as well. Ah.. and I have not fiddled with mergehex or any other trickery so there is no application in the flash nor bootloader settings (but the default zeroes).
Has anyone suggestions what I might have done wrong? Any hint is very much appreciated..
  • Hi jmr,
    Have you modified the bootloader ?
    I assume when you test you don't have any buttonless DFU application, only the bootloader is flashed on the chip ?
    init_softdevice: it's the flag, telling if the softdevice is already running and nrf_dfu_mbr_init_sd() can be skipped or not. You can try to skip nrf_dfu_mbr_init_sd() function and see if the bootloader still works. If it is, meaning you already initialize the softdevice prior to the bootloader.
    Are you testing with nRF5 DK ? Could you updace the question to add the hex file for the bootloader so we can test here ? Also state the logging method you use (RTT or UART, which pin?)
  • Hej Hung Bui,
    My modifications are minor: I changed the Device-Name-String to something else then "DfuTarg", added my own nrf_dfu_enter_check to allow for pin-state driven entry and GPREGRET magic-number entry triggered from app and have my own public-private key set for firmware update. All of these modifications seem to work flawlessly. Your assumption is right, I have at the time of failure only the SD+MBR flashed and my sick bootloader. Skipping nrf_dfu_mbr_init_sd() does not work, this makes the bootloader fail to run at all (also in the mentioned case where the bootloader works normally, just after flashing)
    I have been experimenting a little by applying my modifications to a vanilla SDK-example and then compile and link with gcc using the makefile in the example. That makes a real difference, my bootloader works flawlessly now!!! So therefore I suspect having trouble setting memory map and flash placement right in Segger embedded studio! There must be something I have missed.. maybe a misalignement of a vector-table?? I would be happy if you could take a look on that.. thanks a lot, jmr.
  • Hi Jmr,
    We are going to release SDK v14.1 in the next few days (should be next week) with support for SES. I would suggest to wait for that.
