Using Diode With 4.2V LiPo?
I'm using the NRF51822 for a project that will be powered by a lithium battery. I'm wondering if it would be safe to use a diode (such at this one) to drop the 4.2V LiPo maximum down to the 3.6V operating range. I realize I could use a Lithium Manganese battery to do this but I'll be powering up to 5 leds in the outdoors so I will need something with a larger capacity.
Would this be a safe approach or do I need some kind of regulator?
  • Hello.
    Not sure about safety. You can use it for prototyping.
    However, using a regulator or a buck converter will be better.
    Since you are using a Lithium battery, how are you going to prepare a charging circuit?
    Assuming
    • you use a 1000mAh, or higher, battery
    • the total current consumption will be less than 150mA
    or use a boost converter to power the LEDs
    • you USB to charge the Lithium battery
    then I can recommend TI’s BQ25010RHLR, a Li-ion charger + buck converter.
    This is just an example; if this not your situation,
    contact vendors which sell buck converters and Lithium battery chargers
    and they will provide a suitable one for you.
    If you are interested in the BQ25010RHLR,
    TI E2E question - heat problem
    TI E2E question - schematic for BQ25010, configuring 3V
    check these out.
    -Best regards, MANGO
  • This will work with a few caveat. Make sure its safe across the temperature spectrum and current variations. Vf varies with these parameters. This isn't great practice but it works.
