J-Link does not connect to nrf51822
I want to reprogram a nRF51822 xxAC device on a existing product. I have a J-Link (SEGGER) device with latest firmware. I'm running the SEGGER J-Flash V6.20e utility. I have connected the DIO and CLK lines to the SWD lines on the J-Link I also connected the VTref pin to the VDD of the CPU. It measures 3.0V. Flash utility of the J-Link also reports it as 3.0V The CPU runs on 3.0V Is this ok for programming or must it be 3.3? I measured the DIO and DCLK lines (with a scope) and they don't go higher than 1.2V They also doesnt go anywhere else on the pcb so I'm not sure if this is correct. The PCB is running an app currently so it is definitely working. (NOTE: It might be running the CPU in low power mode or even OFF mode)
Any ideas Why the programmer does not want to Connect? ... and yes, I did connect the ground as well ...
