DFU secure bootloader loads softdevice in application area
I used command:
nrfutil pkg generate --softdevice s130_nrf51_2.0.1_softdevice.hex --hw-version 51 --key-file private.pem sd130v2.0.1_update.zip
to generate package for only softdevice update (nrfutil version 3.3.2). Next I used nRF Connect to update my custom device and realized that bank0 area in bootloader settings is clear (no application image size, crc and bank code) and softdevice was loaded in application area: image description
(UP - beginning of application area, DOWN - memory area after MBR)
Could you help me with this issue? I'd like to update only softdevice, if it's possible.
Thx, Wojtek
  • Hi Wojtek, you can read about the update procedure here.
    In your specific case the available flash for storing the new SoftDevice in Bank 1 alongside the application will be Bootloader Start Address - Address of first flash page after Application End Address`--> 0x37C00 - 0x29000 = 0xEC00 = 59kB. The S130 v2.0.x needs 104kB so the bootloader is forced to use the combined space of Bank0 and Bank1, i.e. Bootloader Start Address - Application Start Address( 0x37C00 - 0x1B000 = 0x1CC00 = 115 kB).
