Cannot build nRF5 SDK Mesh
I am having errors building the examples in the latest SDK for Mesh (nrf5_SDK_for_Mesh_v0.10.0-Alpha_src). I ran cmake -DTOOLCHAIN=gccarmemb -DPLATFORM=nrf52840_xxAA .. in my build directory which appears to be working just fine. However when I do make I have errors linkings the c executable.
[ 25%] Linking C executable beaconing_nrf52840_xxAA_s140_5.0.0-3.alpha.elf
CMakeFiles/beaconing_nrf52840_xxAA_s140_5.0.0-3.alpha.dir/src/main.c.obj: In function `rx_callback':
main.c:(.text.rx_callback+0xdc): undefined reference to `log_printf'
main.c:(.text.rx_callback+0x104): undefined reference to `g_log_debug_msk'
main.c:(.text.rx_callback+0x108): undefined reference to `g_log_debug_level'
main.c:(.text.rx_callback+0x10c): undefined reference to `g_log_hex_digits'
CMakeFiles/beaconing_nrf52840_xxAA_s140_5.0.0-3.alpha.dir/src/main.c.obj: In function `main':
main.c:(.text.startup.main+0x42): undefined reference to `log_init'
main.c:(.text.startup.main+0x5a): undefined reference to `nrf_mesh_rx_cb_set'
main.c:(.text.startup.main+0x66): undefined reference to `advertiser_instance_init'
main.c:(.text.startup.main+0x6e): undefined reference to `advertiser_packet_alloc'
main.c:(.text.startup.main+0x88): undefined reference to `advertiser_packet_send'
main.c:(.text.startup.main+0x98): undefined reference to `nrf_mesh_process'
main.c:(.text.startup.main+0xc0): undefined reference to `log_printf'
main.c:(.text.startup.main+0xe8): undefined reference to `log_printf'
main.c:(.text.startup.main+0x124): undefined reference to `g_log_debug_msk'
main.c:(.text.startup.main+0x128): undefined reference to `log_callback_rtt'
main.c:(.text.startup.main+0x12c): undefined reference to `g_log_debug_level'
...... (didn't copy the full error message)
collect2: error: ld returned 1 exit status
make[2]: *** [examples/beaconing/beaconing_nrf52840_xxAA_s140_5.0.0-3.alpha.elf] Error 1
make[1]: *** [examples/beaconing/CMakeFiles/beaconing_nrf52840_xxAA_s140_5.0.0-3.alpha.dir/all] Error 2
make: *** [all] Error 2
Any idea why?
  • Hi cdugue,
    The specific problem seems to be that the linker can't find the objects from nrf_mesh.c, log.c and advertiser.c. Did you modify the SDK in any way? Which platform are you using? Windows, Linux or Mac OS? I tried replicating your issue by downloading a fresh copy of the SDK and building it in the following way, but it didn't return any errors for me:
    wget www.nordicsemi.com/.../126781 -O mesh_sdk.zip
    unzip mesh_sdk.zip -d mesh_sdk
    mkdir mesh_sdk/build
    cd mesh_sdk/build
    make
    Output from CMake:
    -- Configuring CMake for nRF5 SDK for Bluetooth Mesh 0.10.0-Alpha
    -- Found PythonInterp: /home/ths1/dev/mesh/bin/python (found version "3.5.2")
    -- Found Doxygen: /usr/bin/doxygen (found version "1.8.11") found components:  doxygen dot
    -- Setting build type to 'Release' as none was specified.
    -- SDK_ROOT=/tmp/external/nRF5_SDK_14.0.0_3bcc1f7 --- set with default PATH
    -- Platform: nrf52840_xxAA
    -- Arch: cortex-m4f
    -- SoftDevice: s140_5.0.0-3.alpha
    -- Board: pca10056
    -- PC-Lint executable not found. Linting disabled.
    -- The C compiler identification is GNU 6.3.1
    -- Found assembler: /usr/bin/arm-none-eabi-gcc
    -- Check for working C compiler: /usr/bin/arm-none-eabi-gcc
    -- Check for working C compiler: /usr/bin/arm-none-eabi-gcc -- works
    -- Detecting C compiler ABI info
    -- Detecting C compiler ABI info - done
    -- Detecting C compile features
    -- Detecting C compile features - done
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /tmp/mesh_sdk/build
    Edit: This was done on Ubuntu MATE 16.04.
    Hope this helps,
    Thomas
  • Hi Thomas,
    Thanks for your help. I followed your steps on my mac and it worked just fine, I was able to build the files.
