SD Write Problem
Hi Everyone,
I am trying to record data from ADC to a SD card every 500ms using nrf52832. I am following the fatfs example. Before I had a problem whereby every approximately 10s I would lose a few samples from the ADC as shown by the figure below. I thought the problem was due to the SD card write latency as every 10s I observed an increase in current that usually lasted for around a few hundred milliseconds. After reading around I found that instead of opening and closing the file everytime I wanted to record data onto the SD card I should use f_sync() and this somehow fixed the problem.
But then I still observe this regular increase in write duration, so I was wondering if this is caused by the SD card write latency or is it due to software bugs. And how does the fatfs module handle this (ie when calling f_write) if it's due to SD write latency.
Thanks for the help. Bryan
White lines showing loss of ADC samples x-axis = sample number y-axis = voltage in uV
image description
Significant increase in write duration for the fifth peak
image description
Update: I tested with another SD card and the problem with the missing samples came back. So f_sync did not solve the problem.
Update: 13/11/17
Code For writing to the SD card added.
In Main
while(1)
			if( sampling_done == true)
				sdWrite(data);
			power_manage();
In SAADC callback
		if(p_event->type == NRF_DRV_SAADC_EVT_DONE)
					ret_code_t err_code;
					err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, NUM_OF_CHANNELS);
					int16_t temp[4]={0};
					int8_t notification[8]={0};
					temp[0] = ADC_result_conversion(p_event->data.done.p_buffer[0]);
					temp[1] = ADC_result_conversion(p_event->data.done.p_buffer[1]);
					temp[2] = ADC_result_conversion(p_event->data.done.p_buffer[2]);
					temp[3] = ADC_result_conversion(p_event->data.done.p_buffer[3]);
					NRF_LOG_INFO("ADC event number: %d\r\n", (int)event_cnt);
					NRF_LOG_INFO("CH1: %d.%02d \r\n",	NRF_LOG_FLOAT(temp[0]));
					NRF_LOG_INFO("CH2: %d.%02d \r\n",	NRF_LOG_FLOAT(temp[1]));
					NRF_LOG_INFO("CH3: %d.%02d \r\n", NRF_LOG_FLOAT(temp[2]));
					NRF_LOG_INFO("CH4: %d.%02d \r\n", NRF_LOG_FLOAT(temp[3]));
					NRF_LOG_INFO("\n");
					NRF_LOG_FLUSH();
					memcpy( &data[0]+NUM_OF_CHANNELS*event_cnt, &temp[0], NUM_OF_CHANNELS*2);
					memcpy( &notification[0], &temp[0] , NUM_OF_CHANNELS*2);
					event_cnt++;
					if( event_cnt >= MAX_NUM_SAMPLES)
						//sdWrite(data);
						sampling_done = true;
						event_cnt = 0;
					ble_cus_custom_value_update(&m_cus, notification);
					sample_cnt++;
In sdWrite function
static void sdWrite(int16_t data[])
		FRESULT ff_result;
	  uint32_t bytes_written;
		char buffer[3000] = {0};
		int n=0;
		int counter=0;
		while(counter < MAX_NUM_SAMPLES)
			n += sprintf(&buffer[n], "%d %d %d %d\r\n", data[NUM_OF_CHANNELS*counter], data[NUM_OF_CHANNELS*counter+1], data[NUM_OF_CHANNELS*counter+2], data[NUM_OF_CHANNELS*counter+3]); //format the data to ASCII
			counter++;
			ff_result = f_write(&file, buffer , n , (UINT *) &bytes_written);
			if (ff_result != FR_OK)
					NRF_LOG_INFO("Write failed\r\n.");
				    //NRF_LOG_INFO("%d bytes written.\r\n", bytes_written);
		 NRF_LOG_FLUSH();
		 f_sync(&file);
  • Are you seeing any write errors reported in sdWrite function? I would recommend that you check all error codes related to writing to SD card and check with a debugger that the missing samples are actually sampled and tried written to the card. It would also be interesting if you could measure the current on the nRF chip only, to see if the excessive current is drawn by the chip or the card.
