SDK14 application and peer manager using FDS simultaneously
Test code:SDK14 ble_app_ancs_c
Hey guys, When I used ble_app_ancs_c demo to do FDS, there was a problem! I initialize FDS and register the drop back function。
image description
When I was working with FDS, I found that I didn't go in and complete the callback function!
image description
I consulted the related issues in the forum and found that many of them needed to add fs_sys_event_handler (sys_evt);Is this solution feasible for SDK14?And I didn't find the function in SDK14.
So I have two questions at the moment:
1.How does peer manager and application program operate FDS at the same time in SDK14?
2.Do you need to add fs_sys_event_handler (sys_evt) to SDK14?
Looking forward to your help!
Parents Reply
  • fds doesn't really use the scheduler. However, if NRF_SDH_DISPATCH_MODEL is set to NRF_SDH_DISPATCH_MODEL_APPSH, then the SoftDevice handler (nrf_sdh) schedules events coming from the SoftDevice (including SoC events regarding flash, which fds relies on), instead of processing them in the interrupt context. Thus, you'd need to run app_sched_execute() for fds to work. Hope that makes sense :)
