LPCOMP interrupts are not getting triggered.
I'm trying to use the LPCOMP of the nrf52 telit board.Configured lpcomp with the following settings :
Input : AIN2 Ref : AIN1 ( external ref. of 1.6V) Detection : Crossing
I've initialised the lpcomp and enabled the lpcomp with nrf_drv_lpcomp_enable() My init function is :
static void lpcomp_init(void)
    uint32_t                err_code;
    nrf_drv_lpcomp_config_t config = NRF_DRV_LPCOMP_DEFAULT_CONFIG;
    config.input = NRF_LPCOMP_INPUT_2;
    // initialize LPCOMP driver, from this point LPCOMP will be active and provided
    // event handler will be executed when defined action is detected
    err_code = nrf_drv_lpcomp_init(&config, lpcomp_event_handler);
    nrf_drv_lpcomp_enable();
My handler function is :
static void lpcomp_event_handler(nrf_lpcomp_event_t event)
	 switch(event)
		 case NRF_LPCOMP_EVENT_CROSS:
			 lpcomp_result = nrf_lpcomp_result_get();
			 cross_count++;
When debugging, i do not receive any interrupts and cross count is always zero. Same is observed when i change to internal ref with vtg supply*4/8.
