Referred to the question: devzone.nordicsemi.com/.../
It is possible to make conflict without RTOS? If yes, how do I change priority like emdi said?
Hi Samuel,
if you're not using a RTOS, then the entire application will be running in one single thread so you should not run into any problems with two modules using the FDS at the same time.
Best regards
Bjørn
Happy to help :) I would appreciate if you could mark the answer as accepted/correct by clicking the check mark in the grey circle to the left of the answer.
