I am using ble_app_uart code. My first goal is to execute a function when board connects with an android device. Another goal is to disconnect board from an android device after information was sent. Moreover, to uninitialize radio, advertising execution for defined time interval after board gets disconected .
Can I execute function from here? Or there should be a flag created in here and raised, then function executed in an eternal loop?
static void on_ble_evt(ble_evt_t * p_ble_evt) /*Function for the Application's S110 SoftDevice event handler*/ { uint32_t err_code; static ble_gap_evt_auth_status_t m_auth_status; ble_gap_enc_info_t * p_enc_info; switch (p_ble_evt->header.evt_id) { case BLE_GAP_EVT_CONNECTED: nrf_gpio_pin_set(CONNECTED_LED_PIN_NO); nrf_gpio_pin_clear(ADVERTISING_LED_PIN_NO); m_conn_handle = p_ble_evt->evt.gap_evt.conn_handle; nrf_gpio_pin_write(GPIO_TOGGLE_COMPARE_EVENT, 0); sprintf(siusti_plnasete8,"CONNECTED"); ble_nus_send_string(&m_nus,siusti_plnasete8,10); break; -
Where should I receive an indication that information was sent? I would use it to disconnect my board.
