Delete a single central from the bonded centrals database
Hi, I would like to delete a single bonded central from the bonded centrals database.
I'm looking at the documentation for the function
ble_bondmngr_bonded_central_delete ( uint16_t central_id )
and think that I should get the parameter central_id by calling the function
ble_bondmngr_central_ids_get ( uint16_t * p_central_ids, uint16_t * p_length )
and then find the right central_id inside the central_ids array.
My question is, how can I make an association, at application level, between the values in the central_ids array and the connected centrals? In other words, how can I retrieve the current bonded central id when a central is pairing to my peripheral?
Hope to have explained the problem...
Thanks for any suggestion.
Samuele.
  • Hi Samuele,
    The central id is provided by the bond manager whenever it raises an event. (See central_id inside the ble_bondmngr_evt_t structure.) Whenever the application receives an event from the bond manager, (eg. BLE_BONDMNGR_EVT_NEW_BOND or BLE_BONDMNGR_EVT_CONN_TO_BONDED_CENTRAL.. ), the app can extract the central_id from the bond manager event. That way the app will know the ID of the currently bonded central.
    Hope this explains.
    Cheers, Balaji
