I am having an issue with my SAADC, it seems to hang while calibrating. The flow of my app is as follows, on my main the SAADC is started with saadc_start() , where a calibration happens and I don't get a hanging. Afterwards on the handler of the SAADC I desinitialize the SAADC. Later, I have my battery service (battery_level_update()) that will restart the SAADC in order to take a sample and then while calibrating, the SAADC hangs waiting for calibration outcome.
Any advise why does this occur?
Thanks
PS: I am using SDK12.2 with s132v3
void saadc_handler_interrupt(nrf_drv_saadc_evt_t const * const p_event)
uint32_t err_code;
uint16_t voltage_mV;
nrf_saadc_value_t adc_result;
uint16_t tmp_voltage;
float adc_gain;
NRF_LOG_INFO("SAADC interruption\n");
if (p_event->type == NRF_DRV_SAADC_EVT_CALIBRATEDONE)
m_adc_cal_in_progress = false;
else if (p_event->type == NRF_DRV_SAADC_EVT_DONE)
adc_result = (float) p_event->data.done.p_buffer[0];
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, 1);
err_code = adc_gain_enum_to_real_gain(ADC_GAIN, &adc_gain);
// calling the function that converts the adc reading adc_result into a voltage in mV
err_code = adc_to_batt_voltage(adc_result, &voltage_mV);
NRF_LOG_INFO("Read value from saadc %d [mV]\n",voltage_mV);
//calling the function that will send the battery voltage reading to the BLE stack
batt_event_handler_adc(voltage_mV);
//TODO: disble saadc when not used
// NRF_LOG_INFO("Disabling SAADC...\n");
// nrf_drv_saadc_uninit();
static uint32_t saadc_calibrate( nrf_drv_saadc_config_t saadc_config)
uint32_t err_code;
m_adc_cal_in_progress = true;
err_code = nrf_drv_saadc_calibrate_offset();
while(m_adc_cal_in_progress)
/* Wait for SAADC calibration to finish. */
return M_BATT_STATUS_CODE_SUCCESS;
static uint32_t saadc_start(batt_meas_param_t batt_meas_init)
uint32_t err_code;
nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG;
err_code = nrf_drv_saadc_init(&saadc_config, saadc_handler_interrupt);
// we calibrate the SAADC before configuring it
err_code = saadc_calibrate(saadc_config);
nrf_saadc_channel_config_t channel_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(batt_meas_init.adc_pin_no);
channel_config.burst = NRF_SAADC_BURST_ENABLED;
channel_config.gain = ADC_GAIN;
//channel_config.acq_time = NRF_SAADC_ACQTIME_3US;
err_code = nrf_drv_saadc_channel_init(0, &channel_config);
err_code = nrf_drv_saadc_buffer_convert(m_buffer, ADC_BUF_SIZE);
void battery_level_update(void)
uint32_t err_code;
uint8_t battery_level;
nrf_saadc_event_t saadc_event;
nrf_saadc_event_check(saadc_event);
NRF_LOG_INFO("Battery Level update interruption\r\n");
err_code = saadc_start(batt_meas_init);
err_code = nrf_drv_saadc_sample();
