Flash FDS initialization failure
When the nRF52 micro-controller is programmed through batch file i.e. nrfjprog utility, the flash fds fails to initialize. Every time, flash fds initialization fails, I have code for soft_Reset.
Initialization fails 3 times and then Flash FDS initializes with success.
After a bit of debugging, I found out fds_register(flash_fds_evt_handler) returns with Success. fds_init() returns with Success.
But the flash_fds_evt_handler() never gets called in the first 3 attempts.
Any insight will be helpful.
I have attached the code snippet below. I am using nRF52932 microcontroller, SDK12.2.0, softdevice s132 v3.0.0
ble_stack_init();
// fds must be initialized after the Softdevice, as it uses the system event to run
flash_fds_init();
// must wait for fds to initializ
while(!fds_init_complete)
    power_led_red_on();
    nrf_delay_ms(1000);
    NVIC_SystemReset();
// use fds to get the auth params (first time though, this Writes the default auth params)
load_auth_params();
    I am having the exact same issue with the aggravating factor of the event handler not reacting to the write operation after FDS becomes available (after the three reboots). The fds_write function returns FDS_SUCCESS but the handler is not triggered.
    Best way to do this is to initialize soft-device first followed by all the fds users
    Could you please explain how to do this? I'm running the FDS initialization at the top of the main function of my program, and I am a bit lost in the BLE and NRF code.
    I'm running this at a TY51822r3 Switch Science board.
    Thank you in advance for your help!
