Heart Rate Collector Multilink Capabilities
hello i am using nrf 52840 board with sdk 13.
i use heart rate collector example to connect the 6 heart rate peripheral . Modified the hrc_c example following this link
Heart rate client start working on multi link.
when i connect the first peripheral, everything was working. when try to connect the second peripheral, he just connect and after timeout about 4 second then disconnect and again connect and disconnect and so on .. but this has no effect on the first connection, first connection was stable. only happening with the second connection. he give me the disconnect reason 0x22. i read little bit in the forum then i realize, may be because of the peer manager. then i also remove the peer manager on the client side and also on the peripheral side but still same error.
i also copy the data from the sniffer with peer manager active. test2.pcapng
any guide will be appreciated,
thank you
