Bootloader hangs until I connect with J-Link RTT viewer
I set the NRF_LOG_BACKEND_RTT_ENABLED 1 and NRF_LOG_ENABLED 1 in the bootloader and application. After a reset, the application gets stuck in the bootloader Or maybe (bl starts the app and reboots immediatly back to the bootloader in a loop).
When I open the J-Link RTT viewer, the log is flushed and the appilication starts running fine. I can then reset the device and it goes from bootloader to application without problem.
If I disconnect the j-link or/and exit or/and remove the probe the code continues to run until I reset the device where it get stuck again.
The problem is intermittent, when I start the debugger on the bootloader code and stop it. The code starts running fine again even after reset without RTT viewer connected.
I am puzzled. Any ideas why the RTT would block execution. Thanks,
