I'm looking to add PWM functionality to my design to drive an LED. Examples exist for other devices, and those don't use the SoftDevice. Is there an example or some reference design for making the PWM module work with the nRF51822 and SD?
Hi i have a question .
Do we still need to make main file when we are using this simple example which you have uploaded? and also can you please explain what is this done
#if (PWM_NUM_CHANNELS == 1) void nrf_pwm_init(uint32_t io_select_pwm0, nrf_pwm_mode_t pwm_mode) { pwm_io_ch[0] = io_select_pwm0; nrf_gpio_cfg_output(io_select_pwm0); pwm_running[0] = 0;
pwm_init_common();
} what does io_select_pwm0 represents?
Hi!
There is an issue with flickering when receiving / sending data over BLE. I set priority to 1 and it helped a little bit. I need stable PWM signal with 10 bit resolution and aprox. 250 Hz. Is it possible with this library and reading/writing characteristics at the same time?
Cheers, Patriko
