PWM driver - invert pin
I'm using nRF PWM Driver and I didn't find the way, how to invert logic of PWM. I would like to reach this behaviour:
  • If I set seq_value=0, I want to have PWM signal which is at logic zero for a whole period.
  • If I set seq_value=280, I want to have PWM signal which is at logic 1 for a whole period.
  • If I set seq_value=210, I want to have PWM signal which is at logic 1 75% of period and at logic 0 for 25 % of period.
Now I have exactly inverted behaviour and I'm not able change it. I tried set .output_pins without NRF_DRV_PWM_PIN_INVERTED and nothing changed. Where is the problem?
This is my code:
#define K_HW_GPIO_PWM_OUT1		28
#define K_HW_GPIO_PWM_OUT2		29
#define K_HW_GPIO_PWM_OUT3		30
#define K_HW_GPIO_PWM_OUT4		31
void pwm_init(void)
    nrf_drv_pwm_config_t const config0 =
     .output_pins =
            K_HW_GPIO_PWM_OUT1 | NRF_DRV_PWM_PIN_INVERTED,	// channel 0
            K_HW_GPIO_PWM_OUT2 | NRF_DRV_PWM_PIN_INVERTED,	// channel 1
            K_HW_GPIO_PWM_OUT3 | NRF_DRV_PWM_PIN_INVERTED,	// channel 2
            K_HW_GPIO_PWM_OUT4 | NRF_DRV_PWM_PIN_INVERTED	// channel 3
        .irq_priority = APP_IRQ_PRIORITY_LOWEST,
        .base_clock   = NRF_PWM_CLK_16MHz,
        .count_mode   = NRF_PWM_MODE_UP,
        .top_value    = 280,
        .load_mode    = NRF_PWM_LOAD_INDIVIDUAL,
        .step_mode    = NRF_PWM_STEP_AUTO
    // Init PWM without error handler
    APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm0, &config0, NULL));
Parents Reply
  •     nrf_drv_pwm_config_t const config0 =
            .output_pins =
                CHANNEL0  // channel 0
            .base_clock   = NRF_PWM_CLK_1MHz,
            .top_value    = m_pwm0_top,
        APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm0, &config0, pwm0_handler));
        m_pwm0_seq_values.channel_0 = pwn_level | (1 << 15);
        (void)nrf_drv_pwm_simple_playback(&m_pwm0, &m_pwm0_seq, 1,
                                          NRF_DRV_PWM_FLAG_LOOP);
