About NRF52832 PWM output accuracy and pin problem?
How do you do 1.Now want to set the PWM output frequency is 60 hz, but with an oscilloscope test is 60.24 hz, here more than 0.24 hz.How can I do the precision of the precision of 0.01 hz or 0.05 hz? Procedures and oscilloscope is as follows: top_value=500KHZ/60HZ=8333 image description image description
2.Configuration PWM output pin, it found that not every IO pin can, such as the above procedures in IO mouth only high level 6, there is no PWM, also found 9.10 pin is not PWM output, right?This how to solve?
