Problem with example nrf52 ble_app_blinky
What shoul i do? 0 erro with code
SEGGER J-Link GDB Server V6.20d Command Line Version
 1. JLinkARM.dll V6.20d (DLL compiled
    Sep 29 2017 16:44:59)
    Command line: -if swd -device
    nRF52832_xxAA -endian little -speed
    1000 -port 2331 -swoport 2332
    -telnetport 2333 -vd -ir -localhostonly 1 -singlerun -strict -timeout 0 -nogui
    -----GDB Server start settings-----
    GDBInit file:                  none
    GDB Server Listening port:     2331
    SWO raw output listening port: 2332
    Terminal I/O port:             2333
    Accept remote connection:
    localhost only
    Generate logfile:              off
    Verify download:               on
    Init regs on start:            on
    Silent mode:                   off
    Single run mode:               on
    Target connection timeout:     0 ms
    ------J-Link related settings------
    J-Link Host interface:         USB
    J-Link script:                 none
    J-Link settings file:          none
    ------Target related settings------
    Target device:
    nRF52832_xxAA
    Target interface:              SWD
    Target interface speed:
    1000kHz
    Target endian:
    little
    Connecting to J-Link...
    J-Link is connected.
    Firmware: J-Link
    OB-SAM3U128-V2-NordicSemi compiled
    Jul 24 2017 17:30:12
    Hardware: V1.00
    S/N: 682468135
    Checking target voltage...
    Target voltage: 3.30 V
    Listening on TCP/IP port 2331
    Connecting to target...Connected to
    target
    Waiting for GDB
    connection...Connected to 127.0.0.1
    Reading all registers
    Read 4 bytes @ address 0x00000000
    (Data = 0xFFFFFFFF)
    Read 2 bytes @ address 0x00000000
    (Data = 0xFFFF)
    Received monitor command: speed 1000
    Target interface speed set to 1000
    kHz
    Received monitor command: clrbp
    Received monitor command: reset
    Resetting target
    Received monitor command: halt
    Halting target CPU...
    ...Target halted (PC = 0xFFFFFFFE)
    Received monitor command: regs
    R0 = 00000000, R1 = 00000000, R2 =
    00000000, R3 = 00000000
    R4 = 00000000, R5 = 00000000, R6 =
    00000000, R7 = 00000000
    R8 = 00000000, R9 = 00000000, R10=
    00000000, R11= 00000000
    R12= 00000000, R13= FFFFFFFC, MSP=
    FFFFFFFC, PSP= 00000000
    R14(LR) = FFFFFFFF, R15(PC) =
    FFFFFFFE
    XPSR 01000000, APSR 00000000, EPSR
    01000000, IPSR 00000000
    CFBP 00000000, CONTROL 00, FAULTMASK
    00, BASEPRI 00, PRIMASK 00
    Read 4 bytes @ address 0xFFFFFFFE
    (Data = 0xFFFFFFFF)
    Read 2 bytes @ address 0xFFFFFFFE
    (Data = 0x0000)
    Received monitor command: speed auto
    Select auto target interface speed
    (1000 kHz)
    Received monitor command: flash
    breakpoints 1
    Flash breakpoints enabled
    semihosting enable
    Semi-hosting enabled (Handle on
    BKPT)
    semihosting IOClient 1
    Semihosting I/O set to TELNET Client
    Received monitor command: SWO
    DisableTarget 0xFFFFFFFF
    SWO disabled successfully.
    EnableTarget 0 0 0x1 0
    SWO enabled successfully.
    (Data = 0xFFFF0000)
    (Data = 0x0000)
    Downloading 15952 bytes @ address
    0x00023000 - Verified OK
    Downloading 8360 bytes @ address
    0x00026E50 - Verified OK
    Downloading 80 bytes @ address
    0x00028EF8 - Verified OK
    Downloading 16 bytes @ address
    0x00028F48 - Verified OK
    Downloading 8 bytes @ address
    0x00028F58 - Verified OK
    Downloading 40 bytes @ address
    0x00028F60 - Verified OK
    0x00028F88 - Verified OK
    0x00028F90 - Verified OK
    Downloading 504 bytes @ address
    0x00028F98 - Verified OK
    Downloading 120 bytes @ address
    0x00029190 - Verified OK
    Comparing flash
    [....................] Done.
    Erasing flash
    Programming flash
    Verifying flash
    Writing register (PC = 0x00027954)
    Read 4 bytes @ address 0x00027954
    (Data = 0x4A074906)
    Read 2 bytes @ address 0x00027954
    (Data = 0x4906)
    Resetting target
    FFFFFFFE
    (Data = 0x4A074906)
    (Data = 0x0000)
    Starting target CPU...
    ...Target halted (DBGRQ, PC =
    0xFFFFFFFE)
    (Data = 0xD7FF97E0)
    (Data = 0x0000)
    Read 4 bytes @ address 0xFFFFFFF4
    (Data = 0x00000000)
    Reading 64 bytes @ address
    0xFFFFFFC0
    (Data = 0xFFFFFFFF)
    (Data = 0xFFFFFFFF)
    (Data = 0xFFFFFFFF)
