NRF52832 Maximum number of central links
HI, I found that the maximum number of connections 52832 can only be 15 connections, like this
// <o> NRF_SDH_BLE_CENTRAL_LINK_COUNT - Maximum number of central links.
#ifndef NRF_SDH_BLE_CENTRAL_LINK_COUNT
#define NRF_SDH_BLE_CENTRAL_LINK_COUNT 15
When I set up more than 15 when the compiler will be wrong, I would like to know what method can set the maximum number of links to 20
I am using the example is :
nRF5_SDK_14.1.0_1dda907\examples\ble_central\ble_app_multilink_central\pca10040\s132\arm5_no_packs
  • I found that multiple connected mode, no problem found a service, multi-service diffcult,the matter over describe
  • I don't use db_discovery module and I recommend you not using it for such easy job either. It's probably not ready for multi-server project (as Nordic support team suggested in another Q&A on this forum they work with single Server/Client paradigm - which is incorrect for mutliconnectable GATT devices from my point of view but that's not so important, simply assume you are on your own).
  • hi, endnode, I has changed the file "app_util.h" as your answer, but the maxnum of link count is only 16,if the number bigger than 16  will show this error, how can i fix it?
    ..\..\..\main.c(94): error:  #29: expected an expression
      BLE_LBS_C_ARRAY_DEF(m_lbs_c, NRF_SDH_BLE_CENTRAL_LINK_COUNT);           /**< LED Button client instances. */
    ..\..\..\main.c(95): error:  #29: expected an expression
      BLE_DB_DISCOVERY_ARRAY_DEF(m_db_disc, NRF_SDH_BLE_CENTRAL_LINK_COUNT);  /**< Database discovery module instances. */
    ..\..\..\main.c: 0 warnings, 2 errors
    the sdk_config.h
    // <o> NRF_SDH_BLE_PERIPHERAL_LINK_COUNT - Maximum number of peripheral links.
    #ifndef NRF_SDH_BLE_PERIPHERAL_LINK_COUNT
    #define NRF_SDH_BLE_PERIPHERAL_LINK_COUNT 0
    #define NRF_SDH_BLE_CENTRAL_LINK_COUNT 17
    // <o> NRF_SDH_BLE_TOTAL_LINK_COUNT - Maximum number of total concurrent connections using the default configuration.
    #ifndef NRF_SDH_BLE_TOTAL_LINK_COUNT
    #define NRF_SDH_BLE_TOTAL_LINK_COUNT 17
    app_util.h
     * Copyright (c) 2012 - 2017, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup app_util Utility Functions and Definitions
     * @ingroup app_common
     * @brief Various types and definitions available to all applications.
    #ifndef APP_UTIL_H__
    #define APP_UTIL_H__
    #include <stdint.h>
    #include <stdbool.h>
    #include <stddef.h>
    #include "compiler_abstraction.h"
    #include "nordic_common.h"
    #include "nrf.h"
    #ifdef __cplusplus
    extern "C" {
    //lint -save -e27 -e10 -e19
    #if defined ( __CC_ARM ) && !defined (__LINT__)
    extern char STACK$$Base;
    extern char STACK$$Length;
    #define STACK_BASE    &STACK$$Base
    #define STACK_TOP    ((void*)((uint32_t)STACK_BASE + (uint32_t)&STACK$$Length))
    #elif defined ( __ICCARM__ )
    extern char CSTACK$$Base;
    extern char CSTACK$$Length;
    #define STACK_BASE    &CSTACK$$Base
    #define STACK_TOP    ((void*)((uint32_t)STACK_BASE + (uint32_t)&CSTACK$$Length))
    #elif defined   ( __GNUC__ )
    extern uint32_t __StackTop;
    extern uint32_t __StackLimit;
    #define STACK_BASE    &__StackLimit
    #define STACK_TOP     &__StackTop
    //lint -restore
    enum
        UNIT_0_625_MS = 625,        /**< Number of microseconds in 0.625 milliseconds. */
        UNIT_1_25_MS  = 1250,       /**< Number of microseconds in 1.25 milliseconds. */
        UNIT_10_MS    = 10000       /**< Number of microseconds in 10 milliseconds. */
    /*Segger embedded studio originally has offsetof macro which cannot be used in macros (like STATIC_ASSERT).
      This redefinition is to allow using that. */
    #if defined(__SES_ARM) && defined(__GNUC__)
    #undef offsetof
    #define offsetof(TYPE, MEMBER) __builtin_offsetof (TYPE, MEMBER)
    /**@brief Implementation specific macro for delayed macro expansion used in string concatenation
    * @param[in]   lhs   Left hand side in concatenation
    * @param[in]   rhs   Right hand side in concatenation
    #define STRING_CONCATENATE_IMPL(lhs, rhs) lhs ## rhs
    /**@brief Macro used to concatenate string using delayed macro expansion
    * @note This macro will delay concatenation until the expressions have been resolved
    #define STRING_CONCATENATE(lhs, rhs) STRING_CONCATENATE_IMPL(lhs, rhs)
    #ifndef __LINT__
    #ifdef __GNUC__
    #define STATIC_ASSERT_SIMPLE(EXPR)      _Static_assert(EXPR, "unspecified message")
    #define STATIC_ASSERT_MSG(EXPR, MSG)    _Static_assert(EXPR, MSG)
    #ifdef __CC_ARM
    #define STATIC_ASSERT_SIMPLE(EXPR)      extern char (*_do_assert(void)) [sizeof(char[1 - 2*!(EXPR)])]
    #define STATIC_ASSERT_MSG(EXPR, MSG)    extern char (*_do_assert(void)) [sizeof(char[1 - 2*!(EXPR)])]
    #ifdef __ICCARM__
    #define STATIC_ASSERT_SIMPLE(EXPR)      static_assert(EXPR, "unspecified message")
    #define STATIC_ASSERT_MSG(EXPR, MSG)    static_assert(EXPR, MSG)
    #else // __LINT__
    #define STATIC_ASSERT_SIMPLE(EXPR)      extern char (*_ignore(void))
    #define STATIC_ASSERT_MSG(EXPR, MSG)    extern char (*_ignore(void))
    #define _SELECT_ASSERT_FUNC(x, EXPR, MSG, ASSERT_MACRO, ...) ASSERT_MACRO
     * @brief   Static (i.e. compile time) assert macro.
     * @note The output of STATIC_ASSERT can be different across compilers.
     * Usage:
     * STATIC_ASSERT(expression);
     * STATIC_ASSERT(expression, message);
     * @hideinitializer
    //lint -save -esym(???, STATIC_ASSERT)
    #define STATIC_ASSERT(...)        \
        _SELECT_ASSERT_FUNC(x, ##__VA_ARGS__,                                                           \
                            STATIC_ASSERT_MSG(__VA_ARGS__),                                             \
                            STATIC_ASSERT_SIMPLE(__VA_ARGS__))
    //lint -restore
    /**@brief Implementation details for NUM_VAR_ARGS */
    #define NUM_VA_ARGS_IMPL(                              \
        _0, _1, _2, _3, _4, _5, _6, _7, _8, _9, _10,       \
        _11, _12, _13, _14, _15, _16, _17, _18, _19, _20,  \
        _21, _22, _23, _24, _25, _26, _27, _28, _29, _30,  \
        _31, _32, _33, _34, _35, _36, _37, _38, _39, _40,  \
        _41, _42, _43, _44, _45, _46, _47, _48, _49, _50,  \
        _51, _52, _53, _54, _55, _56, _57, _58, _59, _60,  \
        _61, _62, N, ...) N
    /**@brief Macro to get the number of arguments in a call variadic macro call
     * param[in]    ...     List of arguments
     * @retval  Number of variadic arguments in the argument list
    #define NUM_VA_ARGS(...) NUM_VA_ARGS_IMPL(__VA_ARGS__, 63, 62, 61,  \
        60, 59, 58, 57, 56, 55, 54, 53, 52, 51,                         \
        50, 49, 48, 47, 46, 45, 44, 43, 42, 41,                         \
        40, 39, 38, 37, 36, 35, 34, 33, 32, 31,                         \
        30, 29, 28, 27, 26, 25, 24, 23, 22, 21,                         \
        20, 19, 18, 17, 16, 15, 14, 13, 12, 11,                         \
        10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0)
    #define NUM_VA_ARGS_LESS_1_IMPL(                       \
        _ignored,                                          \
        _61, _62, N, ...) N
    /**@brief Macro to get the number of arguments in a call variadic macro call.
     * First argument is not counted.
    #define NUM_VA_ARGS_LESS_1(...) NUM_VA_ARGS_LESS_1_IMPL(__VA_ARGS__, 63, 62, 61,  \
        10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0, ~)
    /**@brief type for holding an encoded (i.e. little endian) 16 bit unsigned integer. */
    typedef uint8_t uint16_le_t[2];
    /**@brief Type for holding an encoded (i.e. little endian) 32 bit unsigned integer. */
    typedef uint8_t uint32_le_t[4];
    /**@brief Byte array type. */
    typedef struct
        uint16_t  size;                 /**< Number of array entries. */
        uint8_t * p_data;               /**< Pointer to array entries. */
    } uint8_array_t;
    /**@brief Macro for performing rounded integer division (as opposed to truncating the result).
     * @param[in]   A   Numerator.
     * @param[in]   B   Denominator.
     * @return      Rounded (integer) result of dividing A by B.
    #define ROUNDED_DIV(A, B) (((A) + ((B) / 2)) / (B))
    /**@brief Macro for checking if an integer is a power of two.
     * @param[in]   A   Number to be tested.
     * @return      true if value is power of two.
     * @return      false if value not power of two.
    #define IS_POWER_OF_TWO(A) ( ((A) != 0) && ((((A) - 1) & (A)) == 0) )
    /**@brief Macro for converting milliseconds to ticks.
     * @param[in] TIME          Number of milliseconds to convert.
     * @param[in] RESOLUTION    Unit to be converted to in [us/ticks].
    #define MSEC_TO_UNITS(TIME, RESOLUTION) (((TIME) * 1000) / (RESOLUTION))
    /**@brief Macro for performing integer division, making sure the result is rounded up.
     * @details One typical use for this is to compute the number of objects with size B is needed to
     *          hold A number of bytes.
     * @return      Integer result of dividing A by B, rounded up.
    #define CEIL_DIV(A, B)      \
        (((A) + (B) - 1) / (B))
    /**@brief Macro for creating a buffer aligned to 4 bytes.
     * @param[in]   NAME        Name of the buffor.
     * @param[in]   MIN_SIZE    Size of this buffor (it will be rounded up to multiples of 4 bytes).
    #define WORD_ALIGNED_MEM_BUFF(NAME, MIN_SIZE) static uint32_t NAME[CEIL_DIV(MIN_SIZE, sizeof(uint32_t))]
    /**@brief Macro for calculating the number of words that are needed to hold a number of bytes.
     * @details Adds 3 and divides by 4.
     * @param[in]  n_bytes  The number of bytes.
     * @return The number of words that @p n_bytes take up (rounded up).
    #define BYTES_TO_WORDS(n_bytes) (((n_bytes) + 3) >> 2)
    /**@brief The number of bytes in a word.
    #define BYTES_PER_WORD (4)
    /**@brief Macro for increasing a number to the nearest (larger) multiple of another number.
     * @param[in]  alignment  The number to align to.
     * @param[in]  number     The number to align (increase).
     * @return The aligned (increased) @p number.
    #define ALIGN_NUM(alignment, number) ((number - 1) + alignment - ((number - 1) % alignment))
    /**@brief Macro for getting first of 2 parameters.
     * @param[in] a1    First parameter.
     * @param[in] a2    Second parameter.
    #define GET_ARG_1(a1, a2) a1
    /**@brief Macro for getting second of 2 parameters.
    #define GET_ARG_2(a1, a2) a2
    /**@brief Container of macro (borrowed from Linux kernel).
     * This macro returns parent structure address basing on child member address.
     * @param ptr       Address of child type.
     * @param type      Type of parent structure.
     * @param member    Name of child field in parent structure.
     * @return Parent structure address.
    #define CONTAINER_OF(ptr, type, member)                 \
            (type *)((char *)ptr - offsetof(type, member))
     * @brief Define Bit-field mask
     * Macro that defined the mask with selected number of bits set, starting from
     * provided bit number.
     * @param[in] bcnt Number of bits in the bit-field
     * @param[in] boff Lowest bit number
    #define BF_MASK(bcnt, boff) ( ((1U << (bcnt)) - 1U) << (boff) )
     * @brief Get bit-field
     * Macro that extracts selected bit-field from provided value
     * @param[in] val  Value from witch selected bit-field would be extracted
     * @return Value of the selected bits
    #define BF_GET(val, bcnt, boff) ( ( (val) & BF_MASK((bcnt), (boff)) ) >> (boff) )
     * @brief Create bit-field value
     * Value is masked and shifted to match given bit-field
     * @param[in] val  Value to set on bit-field
     * @param[in] bcnt Number of bits for bit-field
     * @param[in] boff Offset of bit-field
     * @return Value positioned of given bit-field.
    #define BF_VAL(val, bcnt, boff) ( (((uint32_t)(val)) << (boff)) & BF_MASK(bcnt, boff) )
     * @name Configuration of complex bit-field
     * @sa BF_CX
    /** @brief Position of bit count in complex bit-field value */
    #define BF_CX_BCNT_POS  0U
    /** @brief Mask of bit count in complex bit-field value */
    #define BF_CX_BCNT_MASK (0xffU << BF_CX_BCNT_POS)
    /** @brief Position of bit position in complex bit-field value */
    #define BF_CX_BOFF_POS  8U
    /** @brief Mask of bit position in complex bit-field value */
    #define BF_CX_BOFF_MASK (0xffU << BF_CX_BOFF_POS)
     * @brief Define complex bit-field
     * Complex bit-field would contain its position and size in one number.
     * @sa BF_CX_MASK
     * @sa BF_CX_POS
     * @sa BF_CX_GET
     * @return The single number that describes the bit-field completely.
    #define BF_CX(bcnt, boff) ( ((((uint32_t)(bcnt)) << BF_CX_BCNT_POS) & BF_CX_BCNT_MASK) | ((((uint32_t)(boff)) << BF_CX_BOFF_POS) & BF_CX_BOFF_MASK) )
     * @brief Get number of bits in bit-field
     * @sa BF_CX
     * @param bf_cx Complex bit-field
     * @return Number of bits in given bit-field
    #define BF_CX_BCNT(bf_cx) ( ((bf_cx) & BF_CX_BCNT_MASK) >> BF_CX_BCNT_POS )
     * @brief Get lowest bit number in the field
     * @sa BF_CX
     * @param[in] bf_cx Complex bit-field
     * @return Lowest bit number in given bit-field
    #define BF_CX_BOFF(bf_cx) ( ((bf_cx) & BF_CX_BOFF_MASK) >> BF_CX_BOFF_POS )
     * @brief Get bit mask of the selected field
     * @sa BF_CX
     * @return Mask of given bit-field
    #define BF_CX_MASK(bf_cx) BF_MASK(BF_CX_BCNT(bf_cx), BF_CX_BOFF(bf_cx))
     * Macro that extracts selected bit-field from provided value.
     * Bit-field is given as a complex value.
     * @sa BF_CX
     * @sa BF_GET
     * @return Value of the selected bits.
    #define BF_CX_GET(val, bf_cx) BF_GET(val, BF_CX_BCNT(bf_cx), BF_CX_BOFF(bf_cx))
     * Value is masked and shifted to match given bit-field.
    #define BF_CX_VAL(val, bf_cx) BF_VAL(val, BF_CX_BCNT(bf_cx), BF_CX_BOFF(bf_cx))
     * @brief Extracting data from the brackets
     * This macro get rid of brackets around the argument.
     * It can be used to pass multiple arguments in logical one argument to a macro.
     * Call it with arguments inside brackets:
     * @code
     * #define ARGUMENTS (a, b, c)
     * BRACKET_EXTRACT(ARGUMENTS)
     * @endcode
     * It would produce:
     * @code
     * a, b, c
     * @endcode
     * @param a Argument with anything inside brackets
     * @return Anything that appears inside the brackets of the argument
     * @note
     * The argument of the macro have to be inside brackets.
     * In other case the compilation would fail.
    #define BRACKET_EXTRACT(a)  BRACKET_EXTRACT_(a)
    #define BRACKET_EXTRACT_(a) BRACKET_EXTRACT__ a
    #define BRACKET_EXTRACT__(...) __VA_ARGS__
     * @brief Check if number of parameters is more than 1
     * @param ... Arguments to count
     * @return 0 If argument count is <= 1
     * @return 1 If argument count is > 1
     * @sa NUM_VA_ARGS
     * @sa NUM_IS_MORE_THAN_1
    #define NUM_VA_ARGS_IS_MORE_THAN_1(...) NUM_IS_MORE_THAN_1(NUM_VA_ARGS(__VA_ARGS__))
     * @brief Check if given numeric value is bigger than 1
     * This macro accepts numeric value, that may be the result of argument expansion.
     * This numeric value is then converted to 0 if it is lover than 1 or to 1 if
     * its value is higher than 1.
     * The generated result can be used to glue it into other macro mnemonic name.
     * @param N Numeric value to check
     * @return 0 If argument is <= 1
     * @return 1 If argument is > 1
     * @note Any existing definition of a form NUM_IS_MORE_THAN_1_PROBE_[N] can
     *       broke the result of this macro
    #define NUM_IS_MORE_THAN_1(N) NUM_IS_MORE_THAN_1_(N)
    #define NUM_IS_MORE_THAN_1_(N)  NUM_IS_MORE_THAN_1_PROBE_(NUM_IS_MORE_THAN_1_PROBE_ ## N, 1)
    #define NUM_IS_MORE_THAN_1_PROBE_(...) GET_VA_ARG_1(GET_ARGS_AFTER_1(__VA_ARGS__))
    #define NUM_IS_MORE_THAN_1_PROBE_0 ~, 0
    #define NUM_IS_MORE_THAN_1_PROBE_1 ~, 0
     * @brief Get the first argument
     * @param ... Arguments to select
     * @return First argument or empty if no arguments are provided
    #define GET_VA_ARG_1(...) GET_VA_ARG_1_(__VA_ARGS__, ) // Make sure that also for 1 argument it works
    #define GET_VA_ARG_1_(a1, ...) a1
     * @brief Get all the arguments but the first one
     * @return All arguments after the first one or empty if less than 2 arguments are provided
    #define GET_ARGS_AFTER_1(...) GET_ARGS_AFTER_1_(__VA_ARGS__, ) // Make sure that also for 1 argument it works
    #define GET_ARGS_AFTER_1_(a1, ...) __VA_ARGS__
     * @brief Size of a field in declared structure
     * Macro that returns the size of the structure field.
     * @param struct_type Variable type to get the field size from
     * @param field Field name to analyze. It can be even field inside field (field.somethingelse.and_another).
     * @return Size of the field
    #define FIELD_SIZE(struct_type, field) sizeof(((struct struct_type*)NULL)->field)
     * @brief Number of elements in field array in declared structure
     * Macro that returns number of elementy in structure field.
     * @return Number of elements in field array
     * @sa FIELD_SIZE
    #define FIELD_ARRAY_SIZE(struct_type, field) (FIELD_SIZE(struct_type, field) / FIELD_SIZE(struct_type, field[0]))
     * @brief Mapping macro
     * Macro that process all arguments using given macro
     * @param ... Macro name to be used for argument processing followed by arguments to process.
     *            Macro should have following form: MACRO(argument)
     * @return All arguments processed by given macro
    #define MACRO_MAP(...) MACRO_MAP_(__VA_ARGS__)
    #define MACRO_MAP_(...) MACRO_MAP_N(NUM_VA_ARGS_LESS_1(__VA_ARGS__), __VA_ARGS__) // To make sure it works also for 2 arguments in total
     * @brief Mapping macro, recursive version
     *  Can be used in @ref MACRO_MAP macro
    #define MACRO_MAP_REC(...) MACRO_MAP_REC_(__VA_ARGS__)
    #define MACRO_MAP_REC_(...) MACRO_MAP_REC_N(NUM_VA_ARGS_LESS_1(__VA_ARGS__), __VA_ARGS__) // To make sure it works also for 2 arguments in total
     * @brief Mapping N arguments macro
     * Macro similar to @ref MACRO_MAP but maps exact number of arguments.
     * If there is more arguments given, the rest would be ignored.
     * @param N   Number of arguments to map
     * @return Selected number of arguments processed by given macro
    #define MACRO_MAP_N(N, ...) MACRO_MAP_N_(N, __VA_ARGS__)
    #define MACRO_MAP_N_(N, ...) CONCAT_2(MACRO_MAP_, N)(__VA_ARGS__, )
     * @brief Mapping N arguments macro, recursive version
     *  Can be used in @ref MACRO_MAP_N macro
    #define MACRO_MAP_REC_N(N, ...) MACRO_MAP_REC_N_(N, __VA_ARGS__)
    #define MACRO_MAP_REC_N_(N, ...) CONCAT_2(MACRO_MAP_REC_, N)(__VA_ARGS__, )
    #define MACRO_MAP_0(           ...)
    #define MACRO_MAP_1( macro, a, ...) macro(a)
    #define MACRO_MAP_2( macro, a, ...) macro(a) MACRO_MAP_1 (macro, __VA_ARGS__, )
    #define MACRO_MAP_3( macro, a, ...) macro(a) MACRO_MAP_2 (macro, __VA_ARGS__, )
    #define MACRO_MAP_4( macro, a, ...) macro(a) MACRO_MAP_3 (macro, __VA_ARGS__, )
    #define MACRO_MAP_5( macro, a, ...) macro(a) MACRO_MAP_4 (macro, __VA_ARGS__, )
    #define MACRO_MAP_6( macro, a, ...) macro(a) MACRO_MAP_5 (macro, __VA_ARGS__, )
    #define MACRO_MAP_7( macro, a, ...) macro(a) MACRO_MAP_6 (macro, __VA_ARGS__, )
    #define MACRO_MAP_8( macro, a, ...) macro(a) MACRO_MAP_7 (macro, __VA_ARGS__, )
    #define MACRO_MAP_9( macro, a, ...) macro(a) MACRO_MAP_8 (macro, __VA_ARGS__, )
    #define MACRO_MAP_10(macro, a, ...) macro(a) MACRO_MAP_9 (macro, __VA_ARGS__, )
    #define MACRO_MAP_11(macro, a, ...) macro(a) MACRO_MAP_10(macro, __VA_ARGS__, )
    #define MACRO_MAP_12(macro, a, ...) macro(a) MACRO_MAP_11(macro, __VA_ARGS__, )
    #define MACRO_MAP_13(macro, a, ...) macro(a) MACRO_MAP_12(macro, __VA_ARGS__, )
    #define MACRO_MAP_14(macro, a, ...) macro(a) MACRO_MAP_13(macro, __VA_ARGS__, )
    #define MACRO_MAP_15(macro, a, ...) macro(a) MACRO_MAP_14(macro, __VA_ARGS__, )
    #define MACRO_MAP_16(macro, a, ...) macro(a) MACRO_MAP_15(macro, __VA_ARGS__, )
    #define MACRO_MAP_17(macro, a, ...) macro(a) MACRO_MAP_16(macro, __VA_ARGS__, )
    #define MACRO_MAP_18(macro, a, ...) macro(a) MACRO_MAP_17(macro, __VA_ARGS__, )
    #define MACRO_MAP_19(macro, a, ...) macro(a) MACRO_MAP_18(macro, __VA_ARGS__, )
    #define MACRO_MAP_20(macro, a, ...) macro(a) MACRO_MAP_19(macro, __VA_ARGS__, )
    #define MACRO_MAP_REC_0(           ...)
    #define MACRO_MAP_REC_1( macro, a, ...) macro(a)
    #define MACRO_MAP_REC_2( macro, a, ...) macro(a) MACRO_MAP_REC_1 (macro, __VA_ARGS__, )
    #define MACRO_MAP_REC_3( macro, a, ...) macro(a) MACRO_MAP_REC_2 (macro, __VA_ARGS__, )
    #define MACRO_MAP_REC_4( macro, a, ...) macro(a) MACRO_MAP_REC_3 (macro, __VA_ARGS__, )
    #define MACRO_MAP_REC_5( macro, a, ...) macro(a) MACRO_MAP_REC_4 (macro, __VA_ARGS__, )
    #define MACRO_MAP_REC_6( macro, a, ...) macro(a) MACRO_MAP_REC_5 (macro, __VA_ARGS__, )
    #define MACRO_MAP_REC_7( macro, a, ...) macro(a) MACRO_MAP_REC_6 (macro, __VA_ARGS__, )
    #define MACRO_MAP_REC_8( macro, a, ...) macro(a) MACRO_MAP_REC_7 (macro, __VA_ARGS__, )
    #define MACRO_MAP_REC_9( macro, a, ...) macro(a) MACRO_MAP_REC_8 (macro, __VA_ARGS__, )
    #define MACRO_MAP_REC_10(macro, a, ...) macro(a) MACRO_MAP_REC_9 (macro, __VA_ARGS__, )
    #define MACRO_MAP_REC_11(macro, a, ...) macro(a) MACRO_MAP_REC_10(macro, __VA_ARGS__, )
    #define MACRO_MAP_REC_12(macro, a, ...) macro(a) MACRO_MAP_REC_11(macro, __VA_ARGS__, )
    #define MACRO_MAP_REC_13(macro, a, ...) macro(a) MACRO_MAP_REC_12(macro, __VA_ARGS__, )
    #define MACRO_MAP_REC_14(macro, a, ...) macro(a) MACRO_MAP_REC_13(macro, __VA_ARGS__, )
    #define MACRO_MAP_REC_15(macro, a, ...) macro(a) MACRO_MAP_REC_14(macro, __VA_ARGS__, )
    #define MACRO_MAP_REC_16(macro, a, ...) macro(a) MACRO_MAP_REC_15(macro, __VA_ARGS__, )
    #define MACRO_MAP_REC_17(macro, a, ...) macro(a) MACRO_MAP_REC_16(macro, __VA_ARGS__, )
    #define MACRO_MAP_REC_18(macro, a, ...) macro(a) MACRO_MAP_REC_17(macro, __VA_ARGS__, )
    #define MACRO_MAP_REC_19(macro, a, ...) macro(a) MACRO_MAP_REC_18(macro, __VA_ARGS__, )
    #define MACRO_MAP_REC_20(macro, a, ...) macro(a) MACRO_MAP_REC_19(macro, __VA_ARGS__, )
     * @brief Mapping macro with current index
     * Basically macro similar to @ref MACRO_MAP, but the processing function would get an argument
     * and current argument index (beginning from 0).
     *            Macro should have following form: MACRO(argument, index)
    #define MACRO_MAP_FOR(...) MACRO_MAP_FOR_(__VA_ARGS__)
    #define MACRO_MAP_FOR_N_LIST 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15
    #define MACRO_MAP_FOR_(...) MACRO_MAP_FOR_N(NUM_VA_ARGS_LESS_1(__VA_ARGS__), __VA_ARGS__)
     * @brief Mapping N arguments macro with current index
     * Macro is similar to @ref MACRO_MAP_FOR but maps exact number of arguments.
    #define MACRO_MAP_FOR_N(N, ...) MACRO_MAP_FOR_N_(N, __VA_ARGS__)
    #define MACRO_MAP_FOR_N_(N, ...) CONCAT_2(MACRO_MAP_FOR_, N)((MACRO_MAP_FOR_N_LIST), __VA_ARGS__, )
    #define MACRO_MAP_FOR_0( n_list,           ...)
    #define MACRO_MAP_FOR_1( n_list, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)))
    #define MACRO_MAP_FOR_2( n_list, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list))) MACRO_MAP_FOR_1 ((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_3( n_list, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list))) MACRO_MAP_FOR_2 ((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_4( n_list, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list))) MACRO_MAP_FOR_3 ((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_5( n_list, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list))) MACRO_MAP_FOR_4 ((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_6( n_list, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list))) MACRO_MAP_FOR_5 ((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_7( n_list, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list))) MACRO_MAP_FOR_6 ((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_8( n_list, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list))) MACRO_MAP_FOR_7 ((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_9( n_list, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list))) MACRO_MAP_FOR_8 ((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_10(n_list, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list))) MACRO_MAP_FOR_9 ((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_11(n_list, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list))) MACRO_MAP_FOR_10((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_12(n_list, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list))) MACRO_MAP_FOR_11((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_13(n_list, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list))) MACRO_MAP_FOR_12((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_14(n_list, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list))) MACRO_MAP_FOR_13((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_15(n_list, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list))) MACRO_MAP_FOR_14((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_16(n_list, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list))) MACRO_MAP_FOR_15((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_17(n_list, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list))) MACRO_MAP_FOR_16((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_18(n_list, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list))) MACRO_MAP_FOR_17((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_19(n_list, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list))) MACRO_MAP_FOR_18((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_20(n_list, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list))) MACRO_MAP_FOR_19((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__, )
     * @brief Mapping macro with current index and parameter
     * Version of @ref MACRO_MAP_FOR that passes also the same parameter to all macros.
     * @param param Parameter that would be passed to each macro call during mapping.
     *              Macro should have following form: MACRO(argument, index, param)
    #define MACRO_MAP_FOR_PARAM(param, ...) MACRO_MAP_FOR_PARAM_(param, __VA_ARGS__)
    #define MACRO_MAP_FOR_PARAM_(param, ...) MACRO_MAP_FOR_PARAM_N(NUM_VA_ARGS_LESS_1(__VA_ARGS__), param, __VA_ARGS__)
     * @brief Mapping N arguments macro with with current index and parameter
    #define MACRO_MAP_FOR_PARAM_N(N, param, ...) MACRO_MAP_FOR_PARAM_N_(N, param, __VA_ARGS__)
    #define MACRO_MAP_FOR_PARAM_N_(N, param, ...) CONCAT_2(MACRO_MAP_FOR_PARAM_, N)((MACRO_MAP_FOR_N_LIST), param, __VA_ARGS__, )
    #define MACRO_MAP_FOR_PARAM_0( n_list, param, ...)
    #define MACRO_MAP_FOR_PARAM_1( n_list, param, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), param)
    #define MACRO_MAP_FOR_PARAM_2( n_list, param, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), param) MACRO_MAP_FOR_PARAM_1 ((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), param, macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_PARAM_3( n_list, param, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), param) MACRO_MAP_FOR_PARAM_2 ((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), param, macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_PARAM_4( n_list, param, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), param) MACRO_MAP_FOR_PARAM_3 ((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), param, macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_PARAM_5( n_list, param, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), param) MACRO_MAP_FOR_PARAM_4 ((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), param, macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_PARAM_6( n_list, param, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), param) MACRO_MAP_FOR_PARAM_5 ((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), param, macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_PARAM_7( n_list, param, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), param) MACRO_MAP_FOR_PARAM_6 ((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), param, macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_PARAM_8( n_list, param, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), param) MACRO_MAP_FOR_PARAM_7 ((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), param, macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_PARAM_9( n_list, param, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), param) MACRO_MAP_FOR_PARAM_8 ((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), param, macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_PARAM_10(n_list, param, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), param) MACRO_MAP_FOR_PARAM_9 ((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), param, macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_PARAM_11(n_list, param, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), param) MACRO_MAP_FOR_PARAM_10((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), param, macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_PARAM_12(n_list, param, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), param) MACRO_MAP_FOR_PARAM_11((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), param, macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_PARAM_13(n_list, param, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), param) MACRO_MAP_FOR_PARAM_12((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), param, macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_PARAM_14(n_list, param, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), param) MACRO_MAP_FOR_PARAM_13((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), param, macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_PARAM_15(n_list, param, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), param) MACRO_MAP_FOR_PARAM_14((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), param, macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_PARAM_16(n_list, param, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), param) MACRO_MAP_FOR_PARAM_15((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), param, macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_PARAM_17(n_list, param, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), param) MACRO_MAP_FOR_PARAM_16((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), param, macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_PARAM_18(n_list, param, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), param) MACRO_MAP_FOR_PARAM_17((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), param, macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_PARAM_19(n_list, param, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), param) MACRO_MAP_FOR_PARAM_18((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), param, macro, __VA_ARGS__, )
    #define MACRO_MAP_FOR_PARAM_20(n_list, param, macro, a, ...) macro(a, GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), param) MACRO_MAP_FOR_PARAM_19((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), param, macro, __VA_ARGS__, )
     * @brief Repeating macro.
     * @param count Count of repeats.
     * @param macro Macro must have the following form: MACRO(arguments).
     * @param ...   Arguments passed to the macro.
     * @return All arguments processed by the given macro.
    #define MACRO_REPEAT(count, macro, ...)     MACRO_REPEAT_(count, macro, __VA_ARGS__)
    #define MACRO_REPEAT_(count, macro, ...)    CONCAT_2(MACRO_REPEAT_, count)(macro, __VA_ARGS__)
    #define MACRO_REPEAT_0(macro, ...)
    #define MACRO_REPEAT_1(macro, ...)  macro(__VA_ARGS__) MACRO_REPEAT_0(macro, __VA_ARGS__)
    #define MACRO_REPEAT_2(macro, ...)  macro(__VA_ARGS__) MACRO_REPEAT_1(macro, __VA_ARGS__)
    #define MACRO_REPEAT_3(macro, ...)  macro(__VA_ARGS__) MACRO_REPEAT_2(macro, __VA_ARGS__)
    #define MACRO_REPEAT_4(macro, ...)  macro(__VA_ARGS__) MACRO_REPEAT_3(macro, __VA_ARGS__)
    #define MACRO_REPEAT_5(macro, ...)  macro(__VA_ARGS__) MACRO_REPEAT_4(macro, __VA_ARGS__)
    #define MACRO_REPEAT_6(macro, ...)  macro(__VA_ARGS__) MACRO_REPEAT_5(macro, __VA_ARGS__)
    #define MACRO_REPEAT_7(macro, ...)  macro(__VA_ARGS__) MACRO_REPEAT_6(macro, __VA_ARGS__)
    #define MACRO_REPEAT_8(macro, ...)  macro(__VA_ARGS__) MACRO_REPEAT_7(macro, __VA_ARGS__)
    #define MACRO_REPEAT_9(macro, ...)  macro(__VA_ARGS__) MACRO_REPEAT_8(macro, __VA_ARGS__)
    #define MACRO_REPEAT_10(macro, ...) macro(__VA_ARGS__) MACRO_REPEAT_9(macro, __VA_ARGS__)
    #define MACRO_REPEAT_11(macro, ...) macro(__VA_ARGS__) MACRO_REPEAT_10(macro, __VA_ARGS__)
    #define MACRO_REPEAT_12(macro, ...) macro(__VA_ARGS__) MACRO_REPEAT_11(macro, __VA_ARGS__)
    #define MACRO_REPEAT_13(macro, ...) macro(__VA_ARGS__) MACRO_REPEAT_12(macro, __VA_ARGS__)
    #define MACRO_REPEAT_14(macro, ...) macro(__VA_ARGS__) MACRO_REPEAT_13(macro, __VA_ARGS__)
    #define MACRO_REPEAT_15(macro, ...) macro(__VA_ARGS__) MACRO_REPEAT_14(macro, __VA_ARGS__)
    #define MACRO_REPEAT_16(macro, ...) macro(__VA_ARGS__) MACRO_REPEAT_15(macro, __VA_ARGS__)
    #define MACRO_REPEAT_17(macro, ...) macro(__VA_ARGS__) MACRO_REPEAT_16(macro, __VA_ARGS__)
    #define MACRO_REPEAT_18(macro, ...) macro(__VA_ARGS__) MACRO_REPEAT_17(macro, __VA_ARGS__)
    #define MACRO_REPEAT_19(macro, ...) macro(__VA_ARGS__) MACRO_REPEAT_18(macro, __VA_ARGS__)
    #define MACRO_REPEAT_20(macro, ...) macro(__VA_ARGS__) MACRO_REPEAT_19(macro, __VA_ARGS__)
     * @brief Repeating macro with current index.
     * Macro similar to @ref MACRO_REPEAT but the processing function gets the arguments
     * and the current argument index (beginning from 0).
     * @param macro Macro must have the following form: MACRO(index, arguments).
    #define MACRO_REPEAT_FOR(count, macro, ...)     MACRO_REPEAT_FOR_(count, macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_(count, macro, ...)    CONCAT_2(MACRO_REPEAT_FOR_, count)((MACRO_MAP_FOR_N_LIST), macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_0(n_list, macro, ...)
    #define MACRO_REPEAT_FOR_1(n_list, macro, ...)  macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_0((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_2(n_list, macro, ...)  macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_1((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_3(n_list, macro, ...)  macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_2((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_4(n_list, macro, ...)  macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_3((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_5(n_list, macro, ...)  macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_4((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_6(n_list, macro, ...)  macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_5((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_7(n_list, macro, ...)  macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_6((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_8(n_list, macro, ...)  macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_7((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_9(n_list, macro, ...)  macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_8((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_10(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_9((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_11(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_10((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_12(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_11((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_13(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_12((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_14(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_13((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_15(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_14((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_16(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_15((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_17(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_16((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_18(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_17((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_19(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_18((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    #define MACRO_REPEAT_FOR_20(n_list, macro, ...) macro(GET_VA_ARG_1(BRACKET_EXTRACT(n_list)), __VA_ARGS__) MACRO_REPEAT_FOR_19((GET_ARGS_AFTER_1(BRACKET_EXTRACT(n_list))), macro, __VA_ARGS__)
    /**@brief Adding curly brace to the macro parameter.
     * Useful in array of structures initialization.
     * @param p Parameter to put into the curly brace. */
    #define PARAM_CBRACE(p) { p },
    /**@brief Function for changing the value unit.
     * @param[in]   value               Value to be rescaled.
     * @param[in]   old_unit_reversal   Reversal of the incoming unit.
     * @param[in]   new_unit_reversal   Reversal of the desired unit.
     * @return      Number of bytes written.
    static __INLINE uint64_t value_rescale(uint32_t value, uint32_t old_unit_reversal, uint16_t new_unit_reversal)
        return (uint64_t)ROUNDED_DIV((uint64_t)value * new_unit_reversal, old_unit_reversal);
    /**@brief Function for encoding a uint16 value.
     * @param[in]   value            Value to be encoded.
     * @param[out]  p_encoded_data   Buffer where the encoded data is to be written.
    static __INLINE uint8_t uint16_encode(uint16_t value, uint8_t * p_encoded_data)
        p_encoded_data[0] = (uint8_t) ((value & 0x00FF) >> 0);
        p_encoded_data[1] = (uint8_t) ((value & 0xFF00) >> 8);
        return sizeof(uint16_t);
    /**@brief Function for encoding a three-byte value.
    static __INLINE uint8_t uint24_encode(uint32_t value, uint8_t * p_encoded_data)
        p_encoded_data[0] = (uint8_t) ((value & 0x000000FF) >> 0);
        p_encoded_data[1] = (uint8_t) ((value & 0x0000FF00) >> 8);
        p_encoded_data[2] = (uint8_t) ((value & 0x00FF0000) >> 16);
        return 3;
    /**@brief Function for encoding a uint32 value.
    static __INLINE uint8_t uint32_encode(uint32_t value, uint8_t * p_encoded_data)
        p_encoded_data[3] = (uint8_t) ((value & 0xFF000000) >> 24);
        return sizeof(uint32_t);
    /**@brief Function for encoding a uint48 value.
    static __INLINE uint8_t uint48_encode(uint64_t value, uint8_t * p_encoded_data)
        p_encoded_data[0] = (uint8_t) ((value & 0x0000000000FF) >> 0);
        p_encoded_data[1] = (uint8_t) ((value & 0x00000000FF00) >> 8);
        p_encoded_data[2] = (uint8_t) ((value & 0x000000FF0000) >> 16);
        p_encoded_data[3] = (uint8_t) ((value & 0x0000FF000000) >> 24);
        p_encoded_data[4] = (uint8_t) ((value & 0x00FF00000000) >> 32);
        p_encoded_data[5] = (uint8_t) ((value & 0xFF0000000000) >> 40);
        return 6;
    /**@brief Function for decoding a uint16 value.
     * @param[in]   p_encoded_data   Buffer where the encoded data is stored.
     * @return      Decoded value.
    static __INLINE uint16_t uint16_decode(const uint8_t * p_encoded_data)
            return ( (((uint16_t)((uint8_t *)p_encoded_data)[0])) |
                     (((uint16_t)((uint8_t *)p_encoded_data)[1]) << 8 ));
    /**@brief Function for decoding a uint16 value in big-endian format.
    static __INLINE uint16_t uint16_big_decode(const uint8_t * p_encoded_data)
            return ( (((uint16_t)((uint8_t *)p_encoded_data)[0]) << 8 ) |
                     (((uint16_t)((uint8_t *)p_encoded_data)[1])) );
    /**@brief Function for decoding a three-byte value.
     * @return      Decoded value (uint32_t).
    static __INLINE uint32_t uint24_decode(const uint8_t * p_encoded_data)
        return ( (((uint32_t)((uint8_t *)p_encoded_data)[0]) << 0)  |
                 (((uint32_t)((uint8_t *)p_encoded_data)[1]) << 8)  |
                 (((uint32_t)((uint8_t *)p_encoded_data)[2]) << 16));
    /**@brief Function for decoding a uint32 value.
    static __INLINE uint32_t uint32_decode(const uint8_t * p_encoded_data)
                 (((uint32_t)((uint8_t *)p_encoded_data)[2]) << 16) |
                 (((uint32_t)((uint8_t *)p_encoded_data)[3]) << 24 ));
    /**@brief Function for decoding a uint32 value in big-endian format.
    static __INLINE uint32_t uint32_big_decode(const uint8_t * p_encoded_data)
        return ( (((uint32_t)((uint8_t *)p_encoded_data)[0]) << 24) |
                 (((uint32_t)((uint8_t *)p_encoded_data)[1]) << 16) |
                 (((uint32_t)((uint8_t *)p_encoded_data)[2]) << 8)  |
                 (((uint32_t)((uint8_t *)p_encoded_data)[3]) << 0) );
     * @brief Function for encoding an uint16 value in big-endian format.
     * @param[out]  p_encoded_data   Buffer where the encoded data will be written.
    static __INLINE uint8_t uint16_big_encode(uint16_t value, uint8_t * p_encoded_data)
        p_encoded_data[0] = (uint8_t) (value >> 8);
        p_encoded_data[1] = (uint8_t) (value & 0xFF);
    /**@brief Function for encoding a uint32 value in big-endian format.
    static __INLINE uint8_t uint32_big_encode(uint32_t value, uint8_t * p_encoded_data)
        *(uint32_t *)p_encoded_data = __REV(value);
    /**@brief Function for decoding a uint48 value.
     * @return      Decoded value. (uint64_t)
    static __INLINE uint64_t uint48_decode(const uint8_t * p_encoded_data)
        return ( (((uint64_t)((uint8_t *)p_encoded_data)[0]) << 0)  |
                 (((uint64_t)((uint8_t *)p_encoded_data)[1]) << 8)  |
                 (((uint64_t)((uint8_t *)p_encoded_data)[2]) << 16) |
                 (((uint64_t)((uint8_t *)p_encoded_data)[3]) << 24) |
                 (((uint64_t)((uint8_t *)p_encoded_data)[4]) << 32) |
                 (((uint64_t)((uint8_t *)p_encoded_data)[5]) << 40 ));
    /** @brief Function for converting the input voltage (in milli volts) into percentage of 3.0 Volts.
     *  @details The calculation is based on a linearized version of the battery's discharge
     *           curve. 3.0V returns 100% battery level. The limit for power failure is 2.1V and
     *           is considered to be the lower boundary.
     *           The discharge curve for CR2032 is non-linear. In this model it is split into
     *           4 linear sections:
     *           - Section 1: 3.0V - 2.9V = 100% - 42% (58% drop on 100 mV)
     *           - Section 2: 2.9V - 2.74V = 42% - 18% (24% drop on 160 mV)
     *           - Section 3: 2.74V - 2.44V = 18% - 6% (12% drop on 300 mV)
     *           - Section 4: 2.44V - 2.1V = 6% - 0% (6% drop on 340 mV)
     *           These numbers are by no means accurate. Temperature and
     *           load in the actual application is not accounted for!
     *  @param[in] mvolts The voltage in mV
     *  @return    Battery level in percent.
    static __INLINE uint8_t battery_level_in_percent(const uint16_t mvolts)
        uint8_t battery_level;
        if (mvolts >= 3000)
            battery_level = 100;
        else if (mvolts > 2900)
            battery_level = 100 - ((3000 - mvolts) * 58) / 100;
        else if (mvolts > 2740)
            battery_level = 42 - ((2900 - mvolts) * 24) / 160;
        else if (mvolts > 2440)
            battery_level = 18 - ((2740 - mvolts) * 12) / 300;
        else if (mvolts > 2100)
            battery_level = 6 - ((2440 - mvolts) * 6) / 340;
            battery_level = 0;
        return battery_level;
    /**@brief Function for checking if a pointer value is aligned to a 4 byte boundary.
     * @param[in]   p   Pointer value to be checked.
     * @return      TRUE if pointer is aligned to a 4 byte boundary, FALSE otherwise.
    static __INLINE bool is_word_aligned(void const* p)
        return (((uintptr_t)p & 0x03) == 0);
     * @brief Function for checking if provided address is located in stack space.
     * @param[in]   ptr Pointer to be checked.
     * @return      true if address is in stack space, false otherwise.
    static __INLINE bool is_address_from_stack(void * ptr)
        if (((uint32_t)ptr >= (uint32_t)STACK_BASE) &&
            ((uint32_t)ptr <  (uint32_t)STACK_TOP) )
            return true;
            return false;
    #ifdef __cplusplus
    #endif // APP_UTIL_H__
  • hi , endnode, I has changed app_util.h as your answer, the max link count has changed from 15 to 16, how can i set 20?
    sdk_config.h
    app_util.h
  • You should also extend MACRO_MAP_FOR_N_LIST:
    #define MACRO_MAP_FOR_N_LIST 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19
