Thingy52 & Bluetooth 5
Hi !
When operating the Thingy52 with it's factory firmware: Is the Thingy 52 choose automaticly which BT protocol to use (BLE 4.1 or Bluetooth 5).
I mean: if i connect the Thingy to an "old" android phone (like samsung s5), will it work automaticly in BLE 4.1 ? and if i connect the Thingy to "new" android phone (like samsung s8), will it work in automaticly in Bluetooth 5 protocol?
B.r, Yuval.
    The BLE versions are inter-operable and compatible. All features in the newer BLE versions need to be negotiated between the Central and the Peripheral before they are enabled on the link. If only one device support a feature, the negotiation will fail, and the feature will not be enabled. If one device doesn't support all the new features, they agree to use only the old features.
    There is one exception though. BLE 4.x devices cannot connect to BLE 5 devices that advertise with 2Mbps PHY (BLE 5 High throughput) or coded PHY(BLE 5 Long range), but Thingy FW uses the 1 MbpsPHY, so this is not a concern here. So there is no issues using the Samsung S5 with BLE 4.1 with the Thingy:52.
  • Yes, "the original firmware" is able to select automaticly to work with "bluetooh 5 procotol".
