dsm_local_unicast_addresses_set() returns NRF_ERROR_FORBIDDEN
I am writing a combined beacon and mesh node using the mesh SDK v0.10.
When dsm_local_unicast_addresses_set() is called in mesh_evt_handler(), which can be found in nrf_mesh_node_config.c a NRF_ERROR_FORBIDDEN error is returned which results in an assert.
What can course this behavior?
This is how i initializes the mesh node:
void beacon_node_init(void)
    static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
    static nrf_mesh_node_config_params_t config_params =
        .company_id					= COMPANY_ID,
        .prov_caps.num_elements		= ACCESS_ELEMENT_COUNT,
        .prov_caps.algorithms		= NRF_MESH_PROV_ALGORITHM_FIPS_P256EC,
        .prov_caps.oob_static_types	= NRF_MESH_PROV_OOB_STATIC_TYPE_SUPPORTED,
        .p_static_data				= static_auth_data,
        .setup_callback				= configuration_setup_cb,
        .complete_callback			= configuration_complete_cb,
        .attention_cb				= NULL,
        .lf_clk_cfg.source			= NRF_CLOCK_LF_SRC_XTAL,
        .lf_clk_cfg.xtal_accuracy	= NRF_CLOCK_LF_XTAL_ACCURACY_20_PPM
    uint32_t err = nrf_mesh_node_config(&config_params);
    ERROR_CHECK(err);
