Thingy GCC App goes straight to DFU
I've compiled a new app with a new BLE service and module to go along with it (for different work than my other question, I can test this service in a generic LE explorer).
I've used the GCC toolchain to build this project, and it compiles fine.
However, if I flash it (using nrf52DK as Jlink in NRFGoStudio), the Thingy just hangs out in DFU mode until I erase/reflash the release firmware from the site.
Is there a bug in the makefile for projects/pca20020_s132? My project is based off of that, with some added files/functions that have all linked in properly. It'll flash ok with the JLink, but that's it.
  • No, it's not a bug. It's just the bootloader checks CRC and find that the new application you flash didn't match with the CRC it stores. I would suggest is to erase the bootloader and flash your application. You can flash the bootloader back later after you done with modifying your firmware. Then you can update your firmware using bootloader (OTA update) or writing to bootloader setting to match the CRC.
