Bluetooth mesh oscillating RSSI
I have been working with Bluetooth mesh. The test I have been performing repeatedly polls a single node and measures the RSSI (as measured from p_message->meta_data.rssi) and number of hops (as measured from p_message->meta_data.ttl) of the reply. I've noticed when a node is at a certain distance away from a receiver, recording the data, the RSSI output oscillates. This has been tested using the nRF52840 pdk as the receiving node, and the nRF52840 & nRF52832 as the polling node. All experimenting was done using nRF5 SDK for Mesh v0.10.0-alpha.
Attached are two graphs demonstrating the behaviour.
polling every 500 ms
polling every 500 ms, it must be noted that the timestamp on this graph reset to 0 during the test, the oscillating behaviour is still clear
polling every 200 ms
polling every 200 ms, at 200 ms the oscillating behaviour begins to look more like a sine wave
note: the green line displays the RSSI (y-axis on the left), the blue line displays the number of hops (y-axis on right), number of hops is not relevant to this question.
Is there an explanation for why the RSSI is behaving like this?
    In addition to the things Matt mentioned, you will also have different RSSI value on different BLE channels(frequency) . You can find more information about this topic in this post here.
    Quote:
    The RSSI on each channel can also vary depending on your surroundings. A signal on a given frequency might e.g. travel more easily through a wall than a different frequency.
