52832 saadc Multi-channel acquisition
HI, When I use the SAADC example, I found that the data collected during the simultaneous 8-channel acquisition has abnormal data on both channels。
I've ported the SAADC program to it :nRF5_SDK_12.3.0_d7731ad\examples\ble_peripheral\ble_app_uart\pca10040\s132\arm5_no_packs
#define SAMPLES_IN_BUFFER 8
volatile uint8_t state = 1;
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(3);
static nrf_saadc_value_t     m_buffer_pool[2][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t     m_ppi_channel;
static uint32_t              m_adc_evt_counter;
void timer_handler(nrf_timer_event_t event_type, void * p_context)
    ret_code_t err_code;
    /* setup m_timer for compare event every 400ms */
    uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 400);
                                   NRF_TIMER_CC_CHANNEL0,
                                   ticks,
                                   NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                   false);
    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                          timer_compare_event_addr,
                                          saadc_sample_task_addr);
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
        int i;
        //NRF_LOG_INFO("ADC event number: %d\r\n", (int)m_adc_evt_counter);
		printf("ADC event number: %d\r\n", (int)m_adc_evt_counter);
        for (i = 0; i < SAMPLES_IN_BUFFER; i++)
            //NRF_LOG_INFO("%d\r\n", p_event->data.done.p_buffer[i]);
			printf("%d\r\n", p_event->data.done.p_buffer[i]);
        m_adc_evt_counter++;
void saadc_init(void)
	nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG;
    saadc_config.resolution = NRF_SAADC_RESOLUTION_12BIT;
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
	nrf_saadc_channel_config_t channel_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
	nrf_saadc_channel_config_t channel_config1 =
	NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN1);
	nrf_saadc_channel_config_t channel_config2 =
	NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN2);
	nrf_saadc_channel_config_t channel_config3 =
	NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN3);
	nrf_saadc_channel_config_t channel_config4 =
	NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN4);
	nrf_saadc_channel_config_t channel_config5 =
	NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN5);
	nrf_saadc_channel_config_t channel_config6 =
	NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN6);
	nrf_saadc_channel_config_t channel_config7 =
	NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN7);
	err_code = nrf_drv_saadc_channel_init(0, &channel_config);
    err_code = nrf_drv_saadc_channel_init(1, &channel_config1);
	err_code = nrf_drv_saadc_channel_init(2, &channel_config2);
	err_code = nrf_drv_saadc_channel_init(3, &channel_config3);
	err_code = nrf_drv_saadc_channel_init(4, &channel_config4);
	err_code = nrf_drv_saadc_channel_init(5, &channel_config5);
	err_code = nrf_drv_saadc_channel_init(6, &channel_config6);
	err_code = nrf_drv_saadc_channel_init(7, &channel_config7);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
    uint32_t err_code;
    bool     erase_bonds;
    //Initialize.
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
    uart_init();
    ble_stack_init();
    gap_params_init();
    services_init();
    advertising_init();
    conn_params_init();
    printf("\r\nUART Start!\r\n");
    err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
	printf("SAADC HAL simple example.\r\n");
	saadc_init();
    saadc_sampling_event_init();
    //Enter main loop.
    for (;;)
        power_manage();
This is the conversion result
ADC event number: 9
40
31
26
336
129
83
66
60
The voltage of these eight channels are the same about 0.6v
