I have two nrf51822 device, on work as GAP Central, another work as GAP Peripheral.The two device use different connection parameters, after the connection is established, Peripheral device send BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST to the Central,usually my code in Central device accept the request and update the connection parameters use
sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
&p_gap_evt->params.conn_param_update_request.conn_params);
function,and now i wanna improve the speed so i ignore the request(mean's i do nothing when i receive BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST event),then after a certain time the connection will disconnect. I debug the code of Peripheral device and found the reason of DISCONNECT_EVENT is 0x16,it seems because "L2Cap connection parameter update timeout", so must I response BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST? If so,what should i do to reject the request? Is sd_ble_gap_conn_param_update(NULL) ok?
Nordic SDK file told me when Central receive BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST it can then:
1、Accept the request and respond with sd_ble_gap_conn_param_update(connection parameters) to update the connection parameters
2、Reject the request and respond with sd_ble_gap_conn_param_update(NULL)
3、Ignore it.
I accept it before, but now i wanna reject it so i ignore it, but no one tell me this will cause connection disconnect.
