Hi ,
I'm new to working with NRF52 and Bluetooth mesh, I wanted to change some parts of the light_switch_client and server projects to be able to send other data than just the 0 and 1 (on or off) values, I want to be able to send uint32_t value , I know that I have to change the struct in simple_on_off models and simple_on_off_common files, but instead of making 4 uint8_t is it possible to just make a single uint_32_t value and send it using (access_model_reliable_publish()), cause I checked this function and the data type in the (access_message_rx_t) and (access_message_tx_t) and they have the pointer to uint8_t value to the first byte of the buffer and the length of the data to send, should I also change them or I'm not allowed to manipulate them?
Thank you for your helps
