TWI easy DMA with uneven RX buffer width
I just tried the example from
github.com/.../nrf52-mpu-easydma-using-gpiote-and-registers
And they are working like a charm. Now I want to change the example to a version where I can read 4 times the gyro via DMA and on the fifth I want to read gyro, acc and mag at once. This would mean that the TX buffer would have 4 times the gyro register and once the read all register. But how would I configure the DMA config.
The current config is:
// Disable the TWIM module while we reconfigure it
NRF_TWIM0->ENABLE = TWIM_ENABLE_ENABLE_Disabled << TWIM_ENABLE_ENABLE_Pos;
NRF_TWIM0->SHORTS = 0;
NVIC_DisableIRQ(SPI0_TWI0_IRQn);
NVIC_ClearPendingIRQ(SPI0_TWI0_IRQn);
// Configure a gpiote channel to generate an event on a polarity change from
// low to high generated the MPU interrupt pin.
uint8_t gpiote_ch_mpu_int_event = 0;
NRF_GPIOTE->CONFIG[gpiote_ch_mpu_int_event] = ( (GPIOTE_CONFIG_MODE_Event   << GPIOTE_CONFIG_MODE_Pos) |
                                                (MPU_INT_PIN                << GPIOTE_CONFIG_PSEL_Pos) |
                                                (GPIOTE_CONFIG_POLARITY_LoToHi << GPIOTE_CONFIG_POLARITY_Pos));
NRF_TWIM0->PSEL.SCL = MPU_TWI_SCL_PIN;
NRF_TWIM0->PSEL.SDA = MPU_TWI_SDA_PIN;
NRF_TWIM0->FREQUENCY = TWI_FREQUENCY_FREQUENCY_K400;
// Load TWI TX buffer into TWI module. Set number of bytes to write pr transfer, max count, to one.
// Disable the EasyDMA list functionality for TWI TX.
NRF_TWIM0->TXD.PTR = (uint32_t)&p_tx_buffer;
NRF_TWIM0->TXD.MAXCNT = 1;
NRF_TWIM0->TXD.LIST = TWIM_TXD_LIST_LIST_Disabled << TWIM_TXD_LIST_LIST_Pos;
// Point to TWI RX buffer. Set number of bytes to read pr transfer, max count, to TWIM_RX_BUF_WIDTH.
NRF_TWIM0->RXD.PTR = (uint32_t)&p_rx_buffer;
NRF_TWIM0->RXD.MAXCNT = TWIM_RX_BUF_WIDTH;
NRF_TWIM0->RXD.LIST = TWIM_RXD_LIST_LIST_ArrayList << TWIM_RXD_LIST_LIST_Pos;
// Make sure that MPU address is set
NRF_TWIM0->ADDRESS = MPU_ADDRESS;
// Enable shortcuts that starts a read right after a write and sends a stop condition after last TWI read
NRF_TWIM0->SHORTS = (TWIM_SHORTS_LASTTX_STARTRX_Enabled << TWIM_SHORTS_LASTTX_STARTRX_Pos) |
                    (TWIM_SHORTS_LASTRX_STOP_Enabled << TWIM_SHORTS_LASTRX_STOP_Pos);
// Configure PPI channel
// Use MPU interrupt pin as event
// Start timer 0 on event to count number of transfers
// Also start TWI transfers on event
// Enable PPI channel
NRF_PPI->CH[0].EEP = (uint32_t)&NRF_GPIOTE->EVENTS_IN[gpiote_ch_mpu_int_event];
NRF_PPI->CH[0].TEP = (uint32_t)&NRF_TIMER0->TASKS_COUNT;
NRF_PPI->FORK[0].TEP = (uint32_t)&NRF_TWIM0->TASKS_STARTTX;
// Enable the TWIM module
NRF_TWIM0->ENABLE = TWIM_ENABLE_ENABLE_Enabled << TWIM_ENABLE_ENABLE_Pos;
Thanks in advance. Constantin
