anyone having problem with the APP_TIMER in SDK14
When using the APP_TIMER in SDK14 I am having a problem with the application stopping. I was using the APP_TIMER to flash LEDs and watch for timeouts in SDK13. when porting the code to SDK14 I am having a problem with the timer functions stopping. I have cut the functions down to the minimum for testing am still having the problem with both the APP_TIMER_MODE_REPEATED and APP_TIMER_MODE_SINGLE_SHOT.
I started with a repeated timer but changed to a single shot for testing. I increased the timer interval from 150 to 2000. I am also using the timer to trigger sensor a reading so the use of soft_led will not solve the issue.
I have been using the timer in SDK14 to watch for loss of signal while doing range testing and have had no problem using the timer in single mode and constantly resetting it, but there were very few timeout events.
on dev board: nrf52840-Preview-DK softdevice s140_nrf52840_6.0.0-6.alpha_softdevice.hex
setting up the timer
define LED_FLASH_TIME 2000
static void timers_init(void) {
err_code = app_timer_create(&low_gate_led_timer_id, APP_TIMER_MODE_SINGLE_SHOT,
		&low_led_timer);
and the timer service routine
void low_led_timer(void * p_context) {
UNUSED_PARAMETER(p_context);
nrf_gpio_pin_toggle(GATE_DOWN_LED);
ret_code_t err_code = app_timer_start(low_gate_led_timer_id,LED_FLASH_TIME,NULL);
    There was no changes in the app timer library between SDK 13 and SDK 14. So it could be something else that is causing the application to stop.
    So if you are having trouble with the application stopping, you should debug and see if you maybe are running in the error-handler? See this post.
  • hello
    yes I have problems with my app_timers in SDK14.2 (migration from 12),
    I well noticed that the prototypes of the functions create and start changed from sdk12.
    	// create timer
    	static app_timer_t timer_data = { {0} };
    	m_timer_id = &timer_data;
    	err_code = app_timer_create(&m_timer_id, APP_TIMER_MODE_REPEATED, cbk_measure);
    this works well
    ret_code_t err_code;
    	err_code = app_timer_start(m_timer_id, APP_TIMER_TICKS(m_probing_interval_ms), (void *) this);
    	NRF_LOG_DEBUG("FIXME: app_timer_start returns %d", err_code);
    	//	APP_ERROR_CHECK(err_code);
    but the start returns error code 8 (invalid param if i remember correctly) and I dotn understand why.
    BTW my timer_ids are C++ class members. I cannot simply use the APP-TIMER_DEF macro. but it was already the case ion SDK12 and worked AFAIK
    thx,
    yacine
  • Hi yacine,
    Error code 8 is NRF_ERROR_INVALID_STATE. You will get this error code if have not initialized the timer module(app_timer_init()). You could also get this error code if your timer_id is 0, or if the timeout_handler function is NULL.
  • Hello Sigurd,
    Thanks for your reply. I verified: app_timer_create is called, the timer _id is not 0, the callback is not NULL.
    I discovered the following with more tests:
    1) this code works only if the temporary variable timer_data is declared static (just like in APP_TIMER_DEF macro. is not static app-timer_create returns SUCCESS, but app_timer_start will return  NRF_ERROR_INVALID_STATE. see below ths code:
    2) now the problem is that m_timer_id is a member of my c++ class and my code breaks when I create a second instance of this class and try to call app_timer_create. it seems like app_timer_create returns NRF_ERROR_INVALID_STATE when the timer_id is already used by another app_timer. Actually the timed_id generated in the second instance constructor has the same value of the previous instance and this leads to app_timer create returning
    see below the logs:
    // first instance
    <debug> FIXME: m_timer_id (before app_timer_create)= 536884956
    <debug> FIXME: app_timer_create returns 0
    <debug> FIXME: m_timer_id (before app_timer_start) = 536884956
    <debug> FIXME: app_timer_start returns 0
    // second instance
    <debug> FIXME: app_timer_create returns 8
    I need to geenerate a different m_timer_id for each class instance. how can I do ?!?!
