nRF52832, STM32 Central w/ Serialization not scanning
I'm trying to implement a BLE Central device on an STM32 using Serialization to connect with an nRF52-DK board; I've previously gotten a BLE Peripheral working on the same setup (in this case I'm not trying to use Central and Peripheral in the same firmware).
I've used the HRS_C example as reference and I can't seem to get a response from scanning / the ble_evt ADV_REPORT. I don't appear to be getting any returned errors (I've double and triple checked that all returned error codes are checked). Once the ble_stack is initialized, bonded pairs are deleted, and scanning is started, I receive no scanned data from the nRF52832.
Edit: Further testing shows that if I try to use the ble_manager_whitelist_disable function, the nRF52832 will stop responding in certain circumstances. I set the timeout to 2 seconds and print when the timeout occurs and the scanning is restarted; I can watch the scanning stop and start and continue to do so until I start advertising on any nearby bluetooth peripheral; at this point the nRF52832 stops responding...
Attached is my code and the decoded SPI packets from Saleae:
central.csv
ble_manager.c
 INCLUDES
//#define USE_EXAMPLE_SERVICES
//Standard Includes
#include <stdbool.h>
#include <stdint.h>
#include <stddef.h>
//This Header
#include "ble_manager.h"
//Application Module Includes
#include "dbg.h"
#include "datetime.h"
//Application Device Includes
#include "ble.h"
#include "ble_hci.h"
#include "ble_db_discovery.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_dis.h"
#include "ble_hrs_c.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "app_timer.h"
#include "peer_manager.h"
#include "nrf_fstorage.h"
#include "fds.h"
#include "nrf_ble_gatt.h"
#include "ble_conn_state.h"
#include "app_scheduler.h"
//ESA MCO CAN Includes
//Device Manufacturer Library Includes
 LOCAL DEFINITIONS
#define APP_BLE_CONN_CFG_TAG                1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_OBSERVER_PRIO               1                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_SOC_OBSERVER_PRIO               1                                   /**< Applications' SoC observer priority. You shoulnd't need to modify this value. */
#define SCAN_INTERVAL               0x00A0                              /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW                 0x00A0                              /**< Determines scan window in units of 0.625 millisecond. */
#define MIN_CONNECTION_INTERVAL                   MSEC_TO_UNITS(400, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.4 seconds). */
#define MAX_CONNECTION_INTERVAL                   MSEC_TO_UNITS(650, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.65 second). */
#define SLAVE_LATENCY                       0                                       /**< Slave latency. */
#define SUPERVISION_TIMEOUT                 MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
#define SEC_PARAM_BOND              1                                   /**< Perform bonding. */
#define SEC_PARAM_MITM              0                                   /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC              0                                   /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS          0                                   /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES   BLE_GAP_IO_CAPS_NONE                /**< No I/O capabilities. */
#define SEC_PARAM_OOB               0                                   /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE      7                                   /**< Minimum encryption key size in octets. */
#define SEC_PARAM_MAX_KEY_SIZE      16                                  /**< Maximum encryption key size in octets. */
#define DEAD_BEEF                           0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define TARGET_UUID                 BLE_UUID_HEART_RATE_SERVICE         /**< Target device name that application is looking for. */
/**@breif Macro to unpack 16bit unsigned UUID from octet stream. */
#define UUID16_EXTRACT(DST, SRC) \
    do                           \
        (*(DST))   = (SRC)[1];   \
        (*(DST)) <<= 8;          \
        (*(DST))  |= (SRC)[0];   \
    } while (0)
/**@brief Variable length data encapsulation in terms of length and pointer to data */
typedef struct
    uint8_t  * p_data;      /**< Pointer to data. */
    uint16_t   data_len;    /**< Length of data. */
} data_t;
#define NRF_LOG_DEBUG(format, ...) DEBUG_PRINTF(DEBUG_CONTROLLER, "NRF_DBG: " format"\n", ##__VA_ARGS__);
#define NRF_LOG_INFO(format, ...) DEBUG_PRINTF(DEBUG_CONTROLLER,  "NRF_LOG: " format "\n", ##__VA_ARGS__);
#define NRF_LOG_ERROR(format, ...) DEBUG_PRINTF(DEBUG_CONTROLLER, "NRF_ERR: " format "\n", ##__VA_ARGS__);
BLE_HRS_C_DEF(m_hrs_c);                                             /**< Structure used to identify the heart rate client module. */
NRF_BLE_GATT_DEF(m_gatt);                                           /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc);                                    /**< DB discovery module instance. */
static uint16_t m_conn_handle         = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
static bool     m_whitelist_disabled;                               /**< True if whitelist has been temporarily disabled. */
static bool     m_memory_access_in_progress;                        /**< Flag to keep track of ongoing operations on persistent memory. */
static bool     m_retry_db_disc;                                    /**< Flag to keep track of whether the DB discovery should be retried. */
static uint16_t m_pending_db_disc_conn = BLE_CONN_HANDLE_INVALID;   /**< Connection handle for which the DB discovery is retried. */
static ble_gap_scan_params_t m_scan_param;                          /**< Scan parameters requested for scanning and connection. */
/**@brief Connection parameters requested for connection. */
static ble_gap_conn_params_t const m_connection_param =
    (uint16_t)MIN_CONNECTION_INTERVAL,  /**< Minimum connection. */
    (uint16_t)MAX_CONNECTION_INTERVAL,  /**< Maximum connection. */
    (uint16_t)SLAVE_LATENCY,            /**< Slave latency. */
    (uint16_t)SUPERVISION_TIMEOUT       /**< Supervision time-out. */
/**@brief Names which the central applications will scan for, and which will be advertised by the peripherals.
 *  if these are set to empty strings, the UUIDs defined below will be used
static char const m_target_periph_name[] = "";      /**< If you want to connect to a peripheral using a given advertising name, type its name here. */
static bool is_connect_per_addr = false;            /**< If you want to connect to a peripheral with a given address, set this to true and put the correct address in the variable below. */
static ble_gap_addr_t const m_target_periph_addr =
    /* Possible values for addr_type:
       BLE_GAP_ADDR_TYPE_PUBLIC,
       BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
       BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_RESOLVABLE,
       BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_NON_RESOLVABLE. */
    .addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
    .addr      = {0x8D, 0xFE, 0x23, 0x86, 0x77, 0xD9}
 EXTERNAL REFERENCES
 PUBLIC DEFINITIONS
 LOCAL FUNCTION PROTOTYPES
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
void assert_nrf_callback(uint16_t line_num, const uint8_t * p_file_name);
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void);
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt);
 * @brief Parses advertisement data, providing length and location of the field in case
 *        matching data is found.
 * @param[in]  Type of data to be looked for in advertisement data.
 * @param[in]  Advertisement report length and pointer to report.
 * @param[out] If data type requested is found in the data report, type data length and
 *             pointer to data will be populated here.
 * @retval NRF_SUCCESS if the data type is found in the report.
 * @retval NRF_ERROR_NOT_FOUND if the data type could not be found.
static uint32_t adv_report_parse(uint8_t type, data_t * p_advdata, data_t * p_typedata);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void);
/**@brief Retrieve a list of peer manager peer IDs.
 * @param[inout] p_peers   The buffer where to store the list of peer IDs.
 * @param[inout] p_size    In: The size of the @p p_peers buffer.
 *                         Out: The number of peers copied in the buffer.
static void peer_list_get(pm_peer_id_t * p_peers, uint32_t * p_size);
static void whitelist_load(void);
static void scan_start(void);
/**@brief GATT module event handler.
static void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt);
/**@brief Function for initializing the GATT module.
static void gatt_init(void);
/**@brief Function for starting application timers.
static void application_timers_start(void);
static void sleep_mode_enter(void);
static void on_adv_evt(ble_adv_evt_t ble_adv_evt);
/**@brief Function for searching a given addr in the advertisement packets.
 * @details Use this function to parse received advertising data and to find a given
 * addr in them.
 * @param[in]   p_adv_report   advertising data to parse.
 * @param[in]   p_addr   name to search.
 * @return   true if the given name was found, false otherwise.
static bool find_peer_addr(const ble_gap_evt_adv_report_t *p_adv_report, const ble_gap_addr_t * p_addr);
/**@brief Function for searching a UUID in the advertisement packets.
 * UUID in them.
 * @param[in]   uuid_to_find   UUIID to search.
 * @return   true if the given UUID was found, false otherwise.
static bool find_adv_uuid(const ble_gap_evt_adv_report_t *p_adv_report, const uint16_t uuid_to_find);
static void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context);
static void ble_stack_init(void);
///**@brief Function for handling events from the BSP module.
// * @param[in]   event   Event generated by button press.
//void bsp_event_handler(bsp_event_t event);
/**@brief Heart Rate Collector Handler.
static void hrs_c_evt_handler(ble_hrs_c_t * p_hrs_c, ble_hrs_c_evt_t * p_hrs_c_evt);
 * @brief Heart rate collector initialization.
static void hrs_c_init(void);
 * @brief Database discovery collector initialization.
static void db_discovery_init(void);
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void);
//static void advertising_init(void);
/**@brief Function for the Power manager.
static void power_manage(void);
 PUBLIC FUNCTIONS
void ble_manager_init(void)
    bool erase_bonds = true;
    // Initialize.
    timers_init();
    ble_stack_init();
    gatt_init();
    peer_manager_init();
    db_discovery_init();
    hrs_c_init();
#if APP_SCHEDULER_ENABLED
    APP_SCHED_INIT(30, 10);
    // Start execution.
    application_timers_start();
    if (erase_bonds == true)
        delete_bonds();
        // Scanning is started by PM_EVT_PEERS_DELETE_SUCCEEDED
        scan_start();
void ble_manager_update(void)
    app_sched_execute();
/**@brief Function for disabling the use of whitelist for scanning.
 void ble_manager_whitelist_disable(void)
    if (!m_whitelist_disabled)
        NRF_LOG_INFO("Whitelist temporarily disabled.");
        m_whitelist_disabled = true;
        sd_ble_gap_scan_stop();
        scan_start();
 LOCAL FUNCTIONS
    ret_code_t err_code;
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
/**@brief Function for handling database discovery events.
 * @details This function is callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function should forward the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_hrs_on_db_disc_evt(&m_hrs_c, p_evt);
//    ble_bas_on_db_disc_evt(&m_bas_c, p_evt);
    DEBUG_PRINTF(DEBUG_MAIN, "%s", "DB Disc Event\n");
    switch (p_evt->evt_id)
        case PM_EVT_BONDED_PEER_CONNECTED:
            NRF_LOG_INFO("Connected to a previously bonded device.");
        } break;
        case PM_EVT_CONN_SEC_SUCCEEDED:
            NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
                         ble_conn_state_role(p_evt->conn_handle),
                         p_evt->conn_handle,
                         p_evt->params.conn_sec_succeeded.procedure);
        } break;
        case PM_EVT_CONN_SEC_FAILED:
            /* Often, when securing fails, it shouldn't be restarted, for security reasons.
             * Other times, it can be restarted directly.
             * Sometimes it can be restarted, but only after changing some Security Parameters.
             * Sometimes, it cannot be restarted until the link is disconnected and reconnected.
             * Sometimes it is impossible, to secure the link, or the peer device does not support it.
             * How to handle this error is highly application dependent. */
        } break;
        case PM_EVT_CONN_SEC_CONFIG_REQ:
            // Reject pairing request from an already bonded peer.
            pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
            pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
        } break;
        case PM_EVT_STORAGE_FULL:
            // Run garbage collection on the flash.
            err_code = fds_gc();
            if (err_code == FDS_ERR_BUSY || err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
                // Retry.
        } break;
            NRF_LOG_DEBUG("PM_EVT_PEERS_DELETE_SUCCEEDED");
            scan_start();
        } break;
        case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
            // The local database has likely changed, send service changed indications.
            pm_local_database_has_changed();
        } break;
        case PM_EVT_PEER_DATA_UPDATE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
        } break;
        case PM_EVT_PEER_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
        } break;
        case PM_EVT_PEERS_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
        } break;
        case PM_EVT_ERROR_UNEXPECTED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
        } break;
        case PM_EVT_CONN_SEC_START:
        case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
        case PM_EVT_PEER_DELETE_SUCCEEDED:
        case PM_EVT_LOCAL_DB_CACHE_APPLIED:
        case PM_EVT_SERVICE_CHANGED_IND_SENT:
        case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
    uint32_t  index = 0;
    uint8_t * p_data;
    p_data = p_advdata->p_data;
    while (index < p_advdata->data_len)
        uint8_t field_length = p_data[index];
        uint8_t field_type   = p_data[index + 1];
        if (field_type == type)
            p_typedata->p_data   = &p_data[index + 2];
            p_typedata->data_len = field_length - 1;
            return NRF_SUCCESS;
        index += field_length + 1;
    return NRF_ERROR_NOT_FOUND;
    // Initialize timer module.
    err_code = app_timer_init();
    pm_peer_id_t peer_id;
    uint32_t     peers_to_copy;
    peers_to_copy = (*p_size < BLE_GAP_WHITELIST_ADDR_MAX_COUNT) ?
                     *p_size : BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
    peer_id = pm_next_peer_id_get(PM_PEER_ID_INVALID);
    *p_size = 0;
    while ((peer_id != PM_PEER_ID_INVALID) && (peers_to_copy--))
        p_peers[(*p_size)++] = peer_id;
        peer_id = pm_next_peer_id_get(peer_id);
static void whitelist_load()
    ret_code_t   ret;
    pm_peer_id_t peers[8];
    uint32_t     peer_cnt;
    memset(peers, PM_PEER_ID_INVALID, sizeof(peers));
    peer_cnt = (sizeof(peers) / sizeof(pm_peer_id_t));
    // Load all peers from flash and whitelist them.
    peer_list_get(peers, &peer_cnt);
    ret = pm_whitelist_set(peers, peer_cnt);
    APP_ERROR_CHECK(ret);
    // Setup the device identies list.
    // Some SoftDevices do not support this feature.
    ret = pm_device_identities_list_set(peers, peer_cnt);
    if (ret != NRF_ERROR_NOT_SUPPORTED)
/**@brief Function to start scanning.
    if (nrf_fstorage_is_busy(NULL))
        m_memory_access_in_progress = true;
        return;
    // Whitelist buffers.
    ble_gap_addr_t whitelist_addrs[8];
    ble_gap_irk_t  whitelist_irks[8];
    memset(whitelist_addrs, 0x00, sizeof(whitelist_addrs));
    memset(whitelist_irks,  0x00, sizeof(whitelist_irks));
    uint32_t addr_cnt = (sizeof(whitelist_addrs) / sizeof(ble_gap_addr_t));
    uint32_t irk_cnt  = (sizeof(whitelist_irks)  / sizeof(ble_gap_irk_t));
    // Reload the whitelist and whitelist all peers.
    whitelist_load();
    ret_code_t ret;
    // Get the whitelist previously set using pm_whitelist_set().
    ret = pm_whitelist_get(whitelist_addrs, &addr_cnt,
                           whitelist_irks,  &irk_cnt);
    m_scan_param.active   = 1;
    m_scan_param.interval = SCAN_INTERVAL;
    m_scan_param.window   = SCAN_WINDOW;
    if (((addr_cnt == 0) && (irk_cnt == 0)) ||
        (m_whitelist_disabled))
        // Don't use whitelist.
        m_scan_param.use_whitelist  = 0;
        m_scan_param.adv_dir_report = 1;
        m_scan_param.timeout  = 0x0000; // No timeout.
        // Use whitelist.
        m_scan_param.use_whitelist  = 1;
        m_scan_param.adv_dir_report = 0;
        m_scan_param.timeout  = 0x001E; // 30 seconds.
    NRF_LOG_INFO("Starting scan.");
    ret = sd_ble_gap_scan_start(&m_scan_param);
//    ret = bsp_indication_set(BSP_INDICATE_SCANNING);
        case NRF_BLE_GATT_EVT_ATT_MTU_UPDATED:
            NRF_LOG_INFO("GATT ATT MTU on connection 0x%x changed to %d.",
                         p_evt->conn_handle,
                         p_evt->params.att_mtu_effective);
        } break;
        case NRF_BLE_GATT_EVT_DATA_LENGTH_UPDATED:
            NRF_LOG_INFO("Data length for connection 0x%x updated to %d.",
                         p_evt->conn_handle,
                         p_evt->params.data_length);
        } break;
    if (m_retry_db_disc)
        NRF_LOG_DEBUG("Retrying DB discovery.");
        m_retry_db_disc = false;
        // Discover peer's services.
        err_code = ble_db_discovery_start(&m_db_disc, m_pending_db_disc_conn);
        if (err_code == NRF_ERROR_BUSY)
            NRF_LOG_DEBUG("ble_db_discovery_start() returned busy, will retry later.");
            m_retry_db_disc = true;
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
/**@brief Function for searching a given name in the advertisement packets.
 * name in them either as 'complete_local_name' or as 'short_local_name'.
 * @param[in]   name_to_find   name to search.
static bool find_adv_name(ble_gap_evt_adv_report_t const * p_adv_report, char const * name_to_find)
    data_t     adv_data;
    data_t     dev_name;
    // Initialize advertisement report for parsing
    adv_data.p_data   = (uint8_t *)p_adv_report->data;
    adv_data.data_len = p_adv_report->dlen;
    //search for advertising names
    err_code = adv_report_parse(BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME, &adv_data, &dev_name);
    if (err_code == NRF_SUCCESS)
        if (memcmp(name_to_find, dev_name.p_data, dev_name.data_len) == 0)
            return true;
        // Look for the short local name if it was not found as complete
        err_code = adv_report_parse(BLE_GAP_AD_TYPE_SHORT_LOCAL_NAME, &adv_data, &dev_name);
        if (err_code != NRF_SUCCESS)
            return false;
        if (memcmp(m_target_periph_name, dev_name.p_data, dev_name.data_len )== 0)
            return true;
    return false;
 * addr in them.
    if (p_addr->addr_type == p_adv_report->peer_addr.addr_type)
        if (memcmp(p_addr->addr, p_adv_report->peer_addr.addr, sizeof(p_adv_report->peer_addr.addr)) == 0)
            return true;
    return false;
 * UUID in them.
    data_t     adv_data;
    data_t     type_data;
    // Initialize advertisement report for parsing.
    err_code = adv_report_parse(BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_MORE_AVAILABLE,
                                &adv_data,
                                &type_data);
        // Look for the services in 'complete' if it was not found in 'more available'.
        err_code = adv_report_parse(BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_COMPLETE,
                                    &adv_data,
                                    &type_data);
            // If we can't parse the data, then exit.
            return false;
    // Verify if any UUID match the given UUID.
    for (uint32_t u_index = 0; u_index < (type_data.data_len / sizeof(uint16_t)); u_index++)
        uint16_t extracted_uuid;
        UUID16_EXTRACT(&extracted_uuid, &type_data.p_data[u_index * sizeof(uint16_t)]);
        if (extracted_uuid == uuid_to_find)
            return true;
    return false;
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected.");
            m_pending_db_disc_conn = p_ble_evt->evt.gap_evt.conn_handle;
                NRF_LOG_INFO("ble_db_discovery_start() returned busy, will retry later.");
//            err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
            if (ble_conn_state_n_centrals() < NRF_SDH_BLE_CENTRAL_LINK_COUNT)
                scan_start();
        } break;
        case BLE_GAP_EVT_ADV_REPORT:
            bool do_connect = false;
            if (is_connect_per_addr)
                if (find_peer_addr(&p_gap_evt->params.adv_report, &m_target_periph_addr))
                    NRF_LOG_INFO("Address match send connect_request.");
                    do_connect = true;
            else if (strlen(m_target_periph_name) != 0)
                if (find_adv_name(&p_gap_evt->params.adv_report, m_target_periph_name))
                    do_connect = true;
                    NRF_LOG_INFO("Name match send connect_request.");
                if (find_adv_uuid(&p_gap_evt->params.adv_report, TARGET_UUID))
                    do_connect = true;
                    NRF_LOG_INFO("UUID match send connect_request.");
            if (do_connect)
                // Stop scanning.
                (void) sd_ble_gap_scan_stop();
                #if (NRF_SD_BLE_API_VERSION <= 2)
                    m_scan_param.selective = 0;
                #if (NRF_SD_BLE_API_VERSION >= 3)
                // Initiate connection.
                err_code = sd_ble_gap_connect(&p_gap_evt->params.adv_report.peer_addr,
                                              &m_scan_param,
                                              &m_connection_param,
                                              APP_BLE_CONN_CFG_TAG);
                m_whitelist_disabled = false;
                    NRF_LOG_ERROR("Connection Request Failed, reason %d.", err_code);
        } break; // BLE_GAP_EVT_ADV_REPORT
            NRF_LOG_INFO("Disconnected, reason 0x%x.",
                         p_ble_evt->evt.gap_evt.params.disconnected.reason);
//            err_code = bsp_indication_set(BSP_INDICATE_IDLE);
            // Reset DB discovery structure.
            memset(&m_db_disc, 0 , sizeof (m_db_disc));
                scan_start();
        } break;
        case BLE_GAP_EVT_TIMEOUT:
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN)
                NRF_LOG_DEBUG("Scan timed out.");
                scan_start();
            else if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_INFO("Connection Request timed out.");
        } break;
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accepting parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                    &p_gap_evt->params.conn_param_update_request.conn_params);
#if defined(S132)
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
/**@brief SoftDevice SoC event handler.
 * @param[in]   evt_id      SoC event.
 * @param[in]   p_context   Context.
static void soc_evt_handler(uint32_t evt_id, void * p_context)
    switch (evt_id)
        case NRF_EVT_FLASH_OPERATION_SUCCESS:
            /* fall through */
        case NRF_EVT_FLASH_OPERATION_ERROR:
            if (m_memory_access_in_progress)
                m_memory_access_in_progress = false;
                scan_start();
            // No implementation needed.
    ret_code_t err_code = 0;
    uint32_t ram_start = 0;
    // Enable BLE stack.
    NRF_SDH_SOC_OBSERVER(m_soc_observer, APP_SOC_OBSERVER_PRIO, soc_evt_handler, NULL);
    switch (p_hrs_c_evt->evt_type)
        case BLE_HRS_C_EVT_DISCOVERY_COMPLETE:
            NRF_LOG_DEBUG("Heart rate service discovered.");
            err_code = ble_hrs_c_handles_assign(p_hrs_c,
                                                p_hrs_c_evt->conn_handle,
                                                &p_hrs_c_evt->params.peer_db);
            // Initiate bonding.
            err_code = pm_conn_secure(p_hrs_c_evt->conn_handle, false);
            // Heart rate service discovered. Enable notification of Heart Rate Measurement.
            err_code = ble_hrs_c_hrm_notif_enable(p_hrs_c);
        } break;
        case BLE_HRS_C_EVT_HRM_NOTIFICATION:
            NRF_LOG_INFO("Heart Rate = %d.", p_hrs_c_evt->params.hrm.hr_value);
            if (p_hrs_c_evt->params.hrm.rr_intervals_cnt != 0)
                uint32_t rr_avg = 0;
                for (uint32_t i = 0; i < p_hrs_c_evt->params.hrm.rr_intervals_cnt; i++)
                    rr_avg += p_hrs_c_evt->params.hrm.rr_intervals[i];
                rr_avg = rr_avg / p_hrs_c_evt->params.hrm.rr_intervals_cnt;
                NRF_LOG_DEBUG("rr_interval (avg) = %d.", rr_avg);
        } break;
    ble_hrs_c_init_t hrs_c_init_obj;
    hrs_c_init_obj.evt_handler = hrs_c_evt_handler;
    ret_code_t err_code = ble_hrs_c_init(&m_hrs_c, &hrs_c_init_obj);
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
static void fds_evt_handler(fds_evt_t const * const p_evt)
    if (p_evt->id == FDS_EVT_GC)
        NRF_LOG_DEBUG("GC completed\n");
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
//    // central
    err_code = fds_register(fds_evt_handler);
    ret_code_t err_code = sd_app_evt_wait();
  • I found an apparent solution to this problem.
    The settings between my STM32 Serialization firmware and the Connectivity / SoftDevice that I loaded weren't the same. In particular changing the below config defines to match between Serialization and Connectivity resolved the issues and I can now see advertising packets and connect accordingly.
    // <o> NRF_SDH_BLE_GAP_EVENT_LENGTH - The time set aside for this connection on every connection interval in 1.25 ms units.
    #ifndef NRF_SDH_BLE_GAP_EVENT_LENGTH
    #define NRF_SDH_BLE_GAP_EVENT_LENGTH 320
    // <o> NRF_SDH_BLE_GATT_MAX_MTU_SIZE - Static maximum MTU size.
    #ifndef NRF_SDH_BLE_GATT_MAX_MTU_SIZE
    #define NRF_SDH_BLE_GATT_MAX_MTU_SIZE 247
    // <o> NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE - Attribute Table size in bytes. The size must be a multiple of 4.
    #ifndef NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE
    #define NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE (1408)
    // <o> NRF_SDH_BLE_VS_UUID_COUNT - The number of vendor-specific UUIDs.
    #ifndef NRF_SDH_BLE_VS_UUID_COUNT
    #define NRF_SDH_BLE_VS_UUID_COUNT 4
