Dear nordic employee:
The service I want to find is the sound service of the thing52thingy sound service
I tried to modify the HRT_central_client project to find the sound service
follows is modify
ret_code_t err_code;
VERIFY_PARAM_NOT_NULL(p_ble_hrs_c);
VERIFY_PARAM_NOT_NULL(p_ble_hrs_c_init);
ble_uuid_t hrs_uuid;
hrs_uuid.type = BLE_UUID_TYPE_VENDOR_BEGIN;
ble_uuid128_t tss_base_uuid={0x42, 0x00, 0x74, 0xA9, 0xFF, 0x52, 0x10, 0x9B, 0x33, 0x49, 0x35, 0x9B, 0x00, 0x00, 0x68, 0xEF};
err_code =sd_ble_uuid_vs_add(&tss_base_uuid, &hrs_uuid.type);
NRF_LOG_INFO("err_code= %d.\r\n", err_code);
hrs_uuid.uuid = 0x0500;
hrs_uuid.type = BLE_UUID_TYPE_BLE;
p_ble_hrs_c->evt_handler = p_ble_hrs_c_init->evt_handler;
p_ble_hrs_c->conn_handle = BLE_CONN_HANDLE_INVALID;
p_ble_hrs_c->peer_hrs_db.hrm_cccd_handle = BLE_GATT_HANDLE_INVALID;
p_ble_hrs_c->peer_hrs_db.hrm_handle = BLE_GATT_HANDLE_INVALID;
return ble_db_discovery_evt_register(&hrs_uuid);
I find sd_ble_uuid_vs_add return 4(NRF_ERROR_BASE_NUM)
blew is the pm_manager setting
#define SEC_PARAM_BOND 1
#define SEC_PARAM_MITM 0
#define SEC_PARAM_LESC 0
#define SEC_PARAM_KEYPRESS 0
#define SEC_PARAM_IO_CAPABILITIES 3
#define SEC_PARAM_OOB 0
#define SEC_PARAM_MIN_KEY_SIZE 7
#define SEC_PARAM_MAX_KEY_SIZE 16
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
AND then I receive ble_db_discovery_evt_t p_evt->evt_type is BLE_DB_DISCOVERY_SRV_NOT_FOUND
but when I modify the uuid value in ble_db_discovery_evt_register :hrt uuid-》0x180f(the battery service of thingy52) then I receive ble_db_discovery_evt_t p_evt->evt_type is BLE_DB_DISCOVERY_COMPLETE
question:
1、should I use the 128bit UUID or 16 bit uuid? 2、how can I set the pm manager?should i change the hrt project pm manager setting?how?
thank you very much!
