- Custom Board which has NordicSemi nRF51822-QFAA (QFAAH0, Rev. 3) MCU,
The board follows the internal LDO setup.
(Ref. nRF51822_PS v3.1 Section 11.3.1)
Softdevice S110 7.1
SDK 7.2 using nrf51-ble-app-temp example (link provided by Hung Bui )
I added LED and button initializing codes.
IAR for ARM 7.1
Testing with iPhone 5S, 6 and iPad air (iOS 8.3)
/ Nexus 5 and Galaxy Note 3 (Android 4.4.2).
Using J-Link Debugger
The scheduler, timers, and BLE settings are all fine.
My problem is that the button init doesn't work properly.
I modified the code in order to divide into files. I don't use the bsp functions.
It seems okay at here. However, after calling any functions,
(in this example, after calling timers_start) the mp_buttons become corrupted.
(calling leds_ok didn't changed mp_buttons.)
So, when I press the button,
it does call detection_delay_timeout_handler in app_button.c
However, it doesn't jumps to the button_event_handler.
Other parts works well. (The timer interrupts, hrs handling, beacon advertising, and etc.)
What could be the reason for the mp_buttons to become corrupted?
What settings did I missed?
The compiler optimization level is "low".
Also, I use the scheduler.
I also tried the bsp_init. Although the event handler function pointer was set to null
err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
NULL);
in this case, the values of mp_buttons didn't change when the program counter changes.
Plus, when a button is pressed, the program jumps to bsp_button_event_handler.
static void bsp_button_event_handler(uint8_t pin_no, uint8_t button_action)
(Although, it doesn't call any functions since the parameter was NULL)
When the program counter comes here, the values of mp_buttons were valid as I configured.
-Regards
