SoftDevice : S110 7.1
SDK 7.2
Example : experimental_ble_app_uart + DFU service
Using IAR 7.1
Board : PCA10001 V 2.0.0 (Rev. 2 MCU)
Test device : Nexus 5 (Android 5.1.1) and iPhone 6+ (iOS 8.4)
Toolbox App Version : 1.14.1 (at Nexus 5) & 2.1 (at iPhone 6+)
Hi, since I don't know Swift, I don't know how the Toolbox app works.
So, if there are some points which I'm missing, please understand my situation.
// at dfu_transport_ble.c
#define DEVICE_NAME "DfuTarg" /* I want to change this name for my own purpose */
#define MANUFACTURER_NAME "NordicSemiconductor"
As you know, after updating the firmware by using the DFU,
my iOS devices remembers my device as DfuTarg
due to memory caching.
After the update, when I connect the board with the UART app,
the connection message says that, it is connected with DfuTarg
and I do not want this to happen.
So, when using the bootloader, I changed the name DfuTarg
to Nordic_UART
I just wanted to maintain the name to see the same message after the firmware update.
However, when I change the device name (in the bootloader code), the Toolbox app
keeps connecting and disconnecting with the board.
So, my question is
the library of the DFU only reconnects when the device name is DfuTarg
In other words, when the bootloader is running, the device name has to be DfuTarg
in order to run the DFU?
If so, after the firmware update is done, I want to cache my device name as the
new name (which is described in the new firmware image, like Nordic_UART
instead of leaving the name as DfuTarg
What implementations are needed?
-Regards
